03 F250 6.0L black smoke, loss of power on hills. HELP! - Ford Truck Enthusiasts Forums
Old 04-22-2010, 11:21 PM
F 250 6 liter's Avatar
F 250 6 liter F 250 6 liter is offline
F 250 6 liter is starting off with a positive reputation.
Hey guys need some major help here. I have a 2003 F 250 6.0L diesel. I replaced all 8 injectors and the EBP sensor, MAP sensor and the fan clutch motor. Fuel filters and oil changed.
152,000 miles on the truck
This was an issue before all the above was completed and is still a major issue.
The truck hesitates going up hills and sometimes on the freeway and blows out black smoke when it hesitates. It is mostly when I step on the gas it does it more often.
No codes showing up at the Ford dealership
Could it be the turbo or something simple?
I also here a flutter sound after I let off the gas from the motor more on the left side. Like a leak maybe or something.
Please help nobody at the dealership knows what is causing this.
Thanks in advance
Old 04-22-2010, 11:25 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
With black smoke and no power, I always start by pulling the EGR valve and cleaning it (as well as cleaning the EBP sensor tube and MAP sensor hose).
Old 04-23-2010, 10:21 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
In addition to what Bismic suggested I would take YOUR suggestion and clean the turbo according to the procedure in the 6.0 tech folder. Also, check all the intercooler hoses and the flex sections of the y-pipe from the exhaust manifolds to the turbo for leaks/cracks while you have the turbo out for cleaning.
Old 04-23-2010, 07:54 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
check the icp sensor and connector. common 03 concerns.
Old 04-23-2010, 11:29 PM
adamtheman16 adamtheman16 is offline
adamtheman16 is gaining momentum as a positive member of FTE.
Black smoke is caused from the engine being over fueled. In your case over fueled at the wrong timing, thus the low power. It sounds like turbo symptoms, but the black smoke is not usually a turbo symptom. Unless it is a little more bluish?
The air sound you hear is the turbocharger sticking causing it to surge back through the intake. If that is indeed the noise you have.
Another thing could be an FICM not fueling the engine correctly (poor metering and timing, black smoke/low power)
I have also seen a bad ECM cause a low power concern while under heavy acceleration. Weird thing is that I swapped an ECM from another truck and it fixed it and the the "bad ecm" worked in the donor truck. Switched them back and same low power. I just swapped them and let it go. Most confusing thing I ever encountered.
Old 04-24-2010, 12:47 PM
steelhead2's Avatar
steelhead2 steelhead2 is offline
steelhead2 has a good reputation on FTE.steelhead2 has a good reputation on FTE.
Quote:
Originally Posted by bismic View Post
With black smoke and no power, I always start by pulling the EGR valve and cleaninig it (as well as cleaning the EBP sensor tube and MAP sensor hose).
+1 here. i had the same symptoms on level ground at cruising speeds as you describe. thats the easiest thing to try first, and like cheezit said.
Old 04-24-2010, 12:49 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
bismic nails this one.
A jammed EGR valve (with carbon particles) or exhaust valves will do the same thing.
04 superduty hesitation, please help Devanwon1 6.0L Power Stroke Diesel 39 01-14-2017 09:29 AM
Buying a USED 6.0L bismic 6.0L Power Stroke Diesel 68 07-12-2016 11:33 PM
Rebuild or new short block? jasoncar40 6.0L Power Stroke Diesel 46 02-17-2014 06:32 AM
2003 6.0L HELP! Loss Of Power Black Smoke F 250 6 liter 6.0L Power Stroke Diesel 14 05-06-2010 03:10 PM
Hesitation+Black Smoke=Problem? bigsteve608 6.0L Power Stroke Diesel 10 07-30-2009 11:08 PM
Tags
03, 1996, 60, 60l, 6liter, black, diesel, f250, ford, hills, loses, map, power, sensor, smoke, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
