F250 4X4 Indicator Lights - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-22-2010, 10:00 PM
Grumpy Moose Grumpy Moose is offline
Grumpy Moose is starting off with a positive reputation.
2001 F250 SD 4X4 5.4L with manual transfer case.
4X4 and "LOW RANGE" lights do not momentarily illuminate when the engine is started like the manual states. 4X4 indicator does not illuminate when the xfer case is shifted to 4X High. However, the "LOW RANGE" light does illuminate when shifted all the way into 4X Low.
Any ideas?
Old 04-23-2010, 01:24 AM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Sounds like the indicator lamp is burned out, Grumpy.
Old 04-23-2010, 07:21 AM
cworley250sd cworley250sd is offline
cworley250sd is starting off with a positive reputation.
Redford has it right, same thing happened on mine right after I bought it, but I also had alot of other lights on the cluster burned out. If you are going to go pull the cluster to replace the 4x4 lights, I would change all the lights even if they are working so you don't have to get back in there. I changed all my lights but the low range light as it was working, got it put back together and 3 days later my low range light no longer works . So now I am waiting till I have to pull the dash apart for something else to fix that one light.
Old 04-23-2010, 10:18 AM
Thanks guys,
Knowing that these lights have a history makes it the most logical place to start, though I was hoping there would be something else "quick & easy" I could check before opening up the dash. It kind of fits too because I noticed my CRUISE light doesn't come on either, even thought the cruise control itself seems to work just fine. Also, I wasn't sure if you could replace individual lights in the instrument cluster, or if it was a sealed unit. Maybe I'll just add this to my growing list of summer projects. It's not like its anything critical, really just the convenience of not having to look down at the shifter to tell if I'm in 4WD or not.
Where did you get the lights? Ford parts counter? Does anyone make LED replacements for these bulbs? This is the 21st century and replacing these tedious little incandecents should be a thing of the past by now!
Old 04-23-2010, 10:21 AM
You can get the lights at any autoparts store Orielly sells bulk packs, there are two sizes, I used 194s for the cluster illumination and IIRC 24s were used for the individual indicator lights (i.e. 4x4, cruise, low range, SES) I know I am right about the 194s but someone feel free to correct me if the 24's are not right, I just remember them being little. HTH.
Old 04-23-2010, 02:10 PM
Rob Cook's Avatar
Rob Cook Rob Cook is offline
Rob Cook is starting off with a positive reputation.
Red Ford has cleared in his first reply is that not enough,
Old 04-23-2010, 04:20 PM
radzer0 radzer0 is offline
radzer0 is starting off with a positive reputation.
I would go thru every single light you can make come on before you pull it apart. You might have another bunch of lights out that you dont notice. Or worst case just replace them all if you plan on keeping the vehicle. Thats what I would do.
Old 04-23-2010, 08:54 PM
Just noticed that the CRUISE light does in fact work. I just didn't notice it before because it's dark green. Not very good human factors engineering on that one!
Its getting harder to justify tearing open the dash just to fix one stupid light!
Old 04-24-2010, 12:39 AM
redford's Avatar
Yes, it does suck. If you decide to dive in, also get a can of compressed air from the local computer section and blow out all the dust you find (and there will be some). You could also use an air hose, but keep the pressure dialed down low.
auto hubs not working aramirez 1999 to 2016 Super Duty 7 01-23-2016 11:23 PM
Strange Unsolved Electrical Phenomenon. Fixnstuff Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 35 08-28-2015 10:31 PM
'96 PSD No- Start - Need a little help Roscoe162 1994.5 - 1997 7.3L Power Stroke Diesel 3 01-19-2015 12:13 PM
2000 F250 front mount hitch VolvoWrench Aftermarket Products 13 04-29-2012 07:55 PM
Removable Mud Flap System "The Trailer Guard " +Coupon!! Tainium Vendor Specials, Discounts, Product Announcements & Group Buys 0 07-22-2011 11:48 AM
Tags
01, 4x4, 99, dash, diesel, f250, ford, indecator, indicator, light, lights, low, range, symbols, warning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
