speedometer broke
speedometer broke
Hi all! My speedometer drive gear bit the dust today. It was a 18 tooth (tan?). Want to order a new one and adjust to the right speed. My speedometer had alway's read 10 mph faster than it should. What gear would you go with? Its a c4 from a 1979. I know there's a formula that can be used. don't want to go threw that. Just want to get it little closer to the right speed. THANK"S for any help!!
My speedometer DRIVEN gear bit the dust today. It was a 18 tooth (tan?). Want to order a new one and adjust to the right speed.
Ford has used the same nylon driven gears from 1960 thru today, so all are available.
Tooth choices: 16-17-18-19-20 & 21.
You will need a 19T gear, this will slow the speedometer down between 7 to 10 MPH.
C7VY17271A .. 19T Driven Gear.
The closest dealer to you that has it in stock is: TISON MOTOR CO in Estill SC who has ONE: 803-625-2551.
Got new 19 tooth speedometer gear installed today, did not change that much with the speed, maybe 4 to 5 mph.slower. I'll try 20 tooth next time. But I'm going to wait to be sure that the old gear was just worn out or if some thing else becauseing the problem? See picture of old gear, it was not worn out evenly all around?Ford Truck Enthusiasts Forums - anderson sc's Album: speedometer gear - Picture
mchbts
04-24-2012 08:17 AM
lildrummer420
10-16-2011 08:38 AM
peterbilttrucker
27
05-03-2009 02:01 PM
jpjahn
62
01-17-2006 11:26 AM
shami02
17
11-28-2001 06:47 PM
