Oxygen Sensors on V6
I have a 99 4.2L V6 with approximatively 126,000 miles on her. The Oxygen Sensors need to be replaced, and I've known it for a little while. I had the light go off before and replaced the one sensor that the code was saying needed replaced. This was about a year ago that I replaced the one sensor and the truck has been running fine since.
Now over the past week it has returned to running extremely rough, worse then before and the light is going off again. I am sure that it is the Oxygen Sensors that need to be replaced and I plan to replace all four sensors this time around.
My question is though, is it alright to go with the Bosch O.E. type or should I spend double the money on the ones from Ford? I want to buy four that are going to run properly like when the truck was new. I'd hate to buy something that is not going to work to the correct specifications of the truck.
Replacing all of the O2 sensors is a waste of beer money anyway.
O2 sensors generally do not cause "running extremely rough" anyway.
O2 sensors are maintenance items, so replacing them is never a waste of money if they are overdue. But you should see what the code is and take care of that first. There are some problems that will damage the sensors. Any time you run rich or get a misfire, it will foul the sensors and catalytic converters, so make sure you resolve all other problems too.
Tom, why the secret about the code #?
The code does not tell you what part to change more than 80% of the time.
There are several codes that have OX sensor in the discription but is not always the cause.
The sensor is the only way the system has of reporting an issue, it detects.
For example a code 174 is not usually an OX sensor but indicitive of an issue with the intake air fault.
Hey, sorry, wasn't being secretive about the codes. Just have not been online here lately
I'll have to get it run again, I can't remember the exact code. I went to AutoZone and had them run it but still have not had the chance to fix it yet. I'll try and run by there tomorrow and have them run it so I can tell you what it is. I have quite a few things going on, maybe we can figure it all out.
Just waiting on the second half of the month to come, if you know what I mean
jpsheb
1999 to 2016 Super Duty
01-23-2013 03:57 PM
