Looking for help - Ford Truck Enthusiasts Forums
Looking for help
Old 04-22-2010, 08:56 PM
Civileng72 Civileng72 is offline
Civileng72 is starting off with a positive reputation.
Unhappy Looking for help
My 72 F100 Bump side with a 302 has a heating problem. It doesn't produce enough heat. The problem is that during cold weather, I cannot get much heat from the heater. Fan blows fine, lots of air. Heater core is brand new, with no restrictions. Thermostat is new - actually the second new one. Temp at the thermostat housing is 190 deg. Heater hoses are new, except for the bypass hose. If it is less than 40 deg., my entire 20 minute ride to work is cold. Any help is appreciated!!
Old 04-23-2010, 12:08 AM
892504x4's Avatar
892504x4 892504x4 is offline
892504x4 has much to be proud of892504x4 has much to be proud of892504x4 has much to be proud of892504x4 has much to be proud of892504x4 has much to be proud of892504x4 has much to be proud of892504x4 has much to be proud of892504x4 has much to be proud of892504x4 has much to be proud of
Did You reverse the hoses to the heater core when You reconnected them. I have done that and no heat until I switched them around that was on an 67 300 6
Old 04-23-2010, 07:01 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
This is a common problem with bump side trucks. The first thing to check is the temp control valve in the heater hose on the passenger side. They will sometimes LOOK like they are working, but the lever is broken inside the housing. Take the valve off and make sure the lever is still connected to the "gate" inside the valve.
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
