C6 transmission band FIX !!!
Old 04-22-2010, 08:27 PM
steves_F350_460's Avatar
steves_F350_460
steves_F350_460 is offline
Hey guys, I'm getting too many stories about this problem and want a striaght answer before I dive in. The C6 tranny in my F-350 skips from 1st to 3rd gear. I just bought the truck a month and a half ago and really have not driven it much since the purchase, but its been doing this since day one. My question is: TO GET TO and REPLACE THE INTERMEDIATE BAND - - - - Do you have to get into the case from the front by separating the tranz from the motor, or can you get to the band by pulling the pan and VB? Thank you sirs!
Old 04-22-2010, 08:33 PM
Hitokori's Avatar
Hitokori
Hitokori is offline
u have to pull the transmission
Old 04-22-2010, 09:01 PM
steves_F350_460
Thanks Matt ...... I was afraid that would be the case, bummer. Just thought I could get'r done by going through the pan.
Old 04-23-2010, 06:14 AM
larrylass's Avatar
larrylass
larrylass is offline
www.badshoeproductions.com amd www.broaderperformance.com are 2 companys you want to contact. Badshoe has the rebuild dvd and broader has the parts for your problem. Check them out!!
BigLar
Old 04-23-2010, 08:06 AM
steves_F350_460
My original thoughts when I purchase this truck was to install an E4OD, which I still plan on doing. With that said, I think I'll just perform a quick fix and install a snap type band in the C6 going through the pan. That should give me time to track down the parts perform the C6 to E4OD conversion, including different length driveshafts and linkage modifications. The the rear trans support member relocation will have to wait until I remove the 3 speed and install the 4 speed OD. Thanks for the links Big, already took a peek and have been helpful. Just hope the old band won't be a PITA to get out !!! Thanks again
Old 04-23-2010, 09:44 AM
quicklook2's Avatar
quicklook2
quicklook2 is offline
i remember buying a band for my 69 lincoln that did not need the trans to be out to replace it.
Old 04-23-2010, 10:05 AM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
Originally Posted by quicklook2
i remember buying a band for my 69 lincoln that did not need the trans to e out to replace it.
Yep, its called a snap band..
You will have to remove the valve body to use one of these.
You cut one end off the old band and slip the new snap band up and over the drum, then put the end on it, the put the "wedge in and the strut rod and adjust as usual..
I'm not sure if they have them for the later model c6, but I know they were available for up to 79 models..
If you get the valve body off and see the intermediate drum is rough, you will have to disassemble as usual because if the drum is the least bit rough you will be wasting your time, talent, and money....
Old 04-23-2010, 10:16 AM
steves_F350_460
Yea, White, I feel ya baby ........ I will definately spy the condition of the drum - thanks for the advise. "roger" on getting the old band out !!! Not sure about talent, but would rather not waste time or money. Going to rain here for the next 3 days, so I may have to wait until next weekend to wrench the situation. Thanks again
warren e
06-20-2017 11:55 AM
F-250 WARHORSE
01-06-2017 07:46 AM
kilich
13
05-10-2016 07:06 AM
arkredneck
1978 - 1996 Big Bronco
10-20-2015 03:39 PM
allwthrrider
10-08-2015 07:45 AM
Quick Reply: C6 transmission band FIX !!!
