C6 transmission band FIX !!! - Ford Truck Enthusiasts Forums
Old 04-22-2010, 09:27 PM
steves_F350_460 steves_F350_460 is offline
steves_F350_460 is starting off with a positive reputation.
Hey guys, I'm getting too many stories about this problem and want a striaght answer before I dive in. The C6 tranny in my F-350 skips from 1st to 3rd gear. I just bought the truck a month and a half ago and really have not driven it much since the purchase, but its been doing this since day one. My question is: TO GET TO and REPLACE THE INTERMEDIATE BAND - - - - Do you have to get into the case from the front by separating the tranz from the motor, or can you get to the band by pulling the pan and VB? Thank you sirs!
Old 04-22-2010, 09:33 PM
Hitokori's Avatar
Hitokori Hitokori is offline
Hitokori is gaining momentum as a positive member of FTE.
u have to pull the transmission
Old 04-22-2010, 10:01 PM
Thanks Matt ...... I was afraid that would be the case, bummer. Just thought I could get'r done by going through the pan.
Old 04-23-2010, 07:14 AM
larrylass larrylass is offline
larrylass is starting off with a positive reputation.
Quote:
www.badshoeproductions.com amd www.broaderperformance.com are 2 companys you want to contact. Badshoe has the rebuild dvd and broader has the parts for your problem. Check them out!!
BigLar
Old 04-23-2010, 09:06 AM
My original thoughts when I purchase this truck was to install an E4OD, which I still plan on doing. With that said, I think I'll just perform a quick fix and install a snap type band in the C6 going through the pan. That should give me time to track down the parts perform the C6 to E4OD conversion, including different length driveshafts and linkage modifications. The the rear trans support member relocation will have to wait until I remove the 3 speed and install the 4 speed OD. Thanks for the links Big, already took a peek and have been helpful. Just hope the old band won't be a PITA to get out !!! Thanks again
Old 04-23-2010, 10:44 AM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
i remember buying a band for my 69 lincoln that did not need the trans to be out to replace it.
Old 04-23-2010, 11:05 AM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is online now
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
Quote:
Originally Posted by quicklook2 View Post
i remember buying a band for my 69 lincoln that did not need the trans to e out to replace it.
Yep, its called a snap band..
You will have to remove the valve body to use one of these.
You cut one end off the old band and slip the new snap band up and over the drum, then put the end on it, the put the "wedge in and the strut rod and adjust as usual..
I'm not sure if they have them for the later model c6, but I know they were available for up to 79 models..
If you get the valve body off and see the intermediate drum is rough, you will have to disassemble as usual because if the drum is the least bit rough you will be wasting your time, talent, and money....
Old 04-23-2010, 11:16 AM
Yea, White, I feel ya baby ........ I will definately spy the condition of the drum - thanks for the advise. "roger" on getting the old band out !!! Not sure about talent, but would rather not waste time or money. Going to rain here for the next 3 days, so I may have to wait until next weekend to wrench the situation. Thanks again
C6 Transmission Band adjustment. kilich 1973 - 1979 F-100 & Larger F-Series Trucks 13 05-10-2016 08:06 AM
Help!!!! C6 band adjustment arkredneck 1978 - 1996 Big Bronco 1 10-20-2015 04:39 PM
Adjusting C6 Intermediate Brake Band allwthrrider Clutch, Transmission, Differential, Axle & Transfer Case 10 10-08-2015 08:45 AM
Power Band Old90Uhaul Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 25 11-01-2013 11:30 AM
c6 band adjustment fail tygerrrr Clutch, Transmission, Differential, Axle & Transfer Case 10 08-30-2009 03:50 PM
Tags
1986, adjusent, band, c6, duty, expedition, f150, fix, fixing, ford, heavy, intermedate, intermediate, repair, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
