You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Year: 1986 Make: Ford Model: F-150 Price: $800 Mileage: 260000 Color: blue Private or Dealer Listing: Private Listing Location (State): VA Transmission: Manual Drivetrain: Rear Wheel Drive Color: Blue Engine: 300 ci IL 6
loads of rust (although MOST is surface rust there is plenty that goes all the way through), all lights work, radio works, heater works, tranny shifts good, (4spd w/ granny gear) engine runs (needs all new seals/gaskets) pm me if you have any questions. the truck in both my garage AND gallery are THIS truck. would like to get atleast what it cost me out of it as i haven't had it more than a few weeks and quite frankly just don't have the time (not to mention the money) to do the work needed. fix the seals on the engine and it would make one hell of a work truck. Wouldn't need to worry about lil dings after all 8P
__________________
Bob Johnson
2001 toyota carrola S (blown engine) - fixed - kaput brakes
1998 Jeep cherokee 4x4 - fixed
1986 f150 2wd (somethin funky w/ the engine so it doesn't work) - sold
1984 ford Bronco 351w - traded for 90- f250+cash
1990 f250 custom 4x4 302 v8
And it seems that you are 250 miles away from me, Im just south of martinsville va. Would the truck be drivable enough to get it home??
no, HOWEVER it only has its issues when the seals result in a dry engine on the inside and a messy one on the outside
__________________
Bob Johnson
that really depends bud, i drove it about 800 miles before the seals began spitting oil out fast enough to be a problem.
__________________
Bob Johnson
not yet - and it looks like i need to replace the starter solenoid (i think) could be something else
__________________
Bob Johnson
If you can do a compression test on it sometime, just to make sure the head gasket and rings are ok. Also, can you pull one of the plugs to make sure there isnt any excessive oil seepage into the combustion chamber.
If this checks out, then Ill beg to grandad to let me use his trailer ti come up there. Thanks in advance.
__________________
86 "heavy" 250. 750HP 460,ZF5 and Gearvender, Sterling axle (3.55)
84 C30 3+3 package. 454, SM465, Dana 60 (4.11)
85 F350. 6.9, T19, NP235, Dana 70 rear, Dana 60 front (4.10)
i'll see if autozone can loan me the tools to do that then
__________________
Bob Johnson
i'll prolly be able to check that sunday or monday if they are willing to
__________________
Bob Johnson
__________________
Bob Johnson
the oil does not however seem to be leaking (much) into the chamber
__________________
Bob Johnson
how much would you be willing to pay if i'm not able to get the compression test done? just out of curiosity
__________________
Bob Johnson
yep thats correct - go ahead and give me a call if you want to talk about it - 703 349 1098
__________________
Bob Johnson
