Engine Squeak/Chirp
Old 04-22-2010, 10:09 AM
Jackson1991's Avatar
Jackson1991
Jackson1991 is offline
Unhappy Engine Squeak/Chirp
I have a 1997 Ford Ranger 5 speed RWD with a 3.0L V6 engine. I have had a problem for about two years now of a constant engine squeak. It seems to go away with belt dressing so I figured it had something to do with the belt and the pulleys. I changed the idler pulley, the tensioner pulley, and the belt and it still squeaks. I then thought to check the A/C compressor clutch and it seemed to be coming from there, I sprayed some WD-40 on the clutch and the engine was perfectly quiet. I did this again a few more times and each time it quieted the engine. I was almost certain it was the A/C compressor clutch but after I changed it last night it was quiet, but this morning it started squeaking again. At this point I can't think of what the problem might be. Please post any information that might lead to the discovery of my annoying engine squeak problem.
Old 04-22-2010, 10:26 AM
bigredtruck's Avatar
bigredtruck
bigredtruck is offline
After further research, I found this thread:
https://www.ford-trucks.com/forums/8...of-engine.html
Sounds like my problem. Engine has 106,000 miles on it, I guess its time. I bucked up and got the Motorcraft one from Rock Auto.
Old 04-22-2010, 10:29 AM
Rockledge's Avatar
Rockledge
Rockledge is offline
You have ascertain where the noise is coming from. Since yours is the 3.0L, it could be a belt/pulley issue, or it could be a camshaft synchronizer issue.
See: https://www.ford-trucks.com/forums/8...ing-noise.html
https://www.ford-trucks.com/forums/2...placement.html
Old 04-22-2010, 10:36 AM
Jackson1991
Okay
Alright, so take the belt off and start it up and if it squeaks, check the Cam Sensor ?
Old 04-22-2010, 12:09 PM
97ranger xlt's Avatar
97ranger xlt
97ranger xlt is offline
you can also check the alternator- mine squeaked due to dry bearings.
Old 04-26-2010, 10:30 AM
Jackson1991
Smile Fixed
My tensioner separated the same day I posted the first time and it was angled out toward the radiator and it was kicking my belt off. I changed the tensioner and the squeak is gone.
Old 05-26-2010, 06:40 PM
mjbogle's Avatar
mjbogle
mjbogle is offline
98 ranger
I had a squeak in a 98 ranger with a 4.0 six, it was the under the intake manifold were the pickup was for the electronic ignition, looks like half a distributor (were a distributor used to be in older models), I had tried everything idler puller tension-er , new alternator, I was way off..
Old 05-26-2010, 06:49 PM
g_k50's Avatar
g_k50
g_k50 is offline
Is that what they call a cam position sensor?
Old 05-26-2010, 10:31 PM
mjbogle's Avatar
mjbogle
mjbogle is offline
98 ranger
I think that is what is called it runs off of the cam, fortunatly now they have them available aftermarket, when mine went out it was 295.00 from the dealer
Coachhick
1999 to 2016 Super Duty
02-19-2016 02:44 PM
rob_jones
09-11-2015 10:15 AM
AllaboutMPG
01-03-2014 01:51 PM
F350-6
39
04-13-2013 08:47 AM
4WheelDriveVan
1997 - 2003 F150
12-10-2010 07:30 AM
Quick Reply: Engine Squeak/Chirp
