Need wiring diagrams for speed control fix
Does anybody have the Powertrain Control/Emissions Diagnosis Manual for 1995? I am trying to fix my cruise control that quit working after I installed am ZF5 tranny in my truck.
All the manuals I have found on this and other forums refer me to the Powertrain Control/Emissions Diagnosis Manual for speed control on the diesel.
Help! Long hauls are killing me with no cruise control!!
Wasn't there a TSB on this issue?
FORD TSB's (technical service bulletins)
A solenoid...?
EDIT: Did you change from an auto to the stick?
A solenoid...?
Have the sensor on the end of the master cylinder checked (BPA), it's the subject of a recall for causing fires. The dealer will replace it for free.
TEST: Unplug the BPA and place a jumper into the harness side. If the CC works the switch is bad. Do not use it this way, the CC may not disengage.
The CC needs a signal from the neutral safety switch (TRS on side of trans) or from the Clutch Pedal Position switch. Not sure if the PCM needs a re-flash if it was converted from auto to stick or vice-versa.
I will check the sensor. I had the wiring harness replaced, as part of that big recall for the fires, but it worked after that until I installed the manual tranny.
I had DP Tuners reflash the computer for the manual and I have tested the CPP. It functions properly. I even reinstalled that little jumper cap on the harness to the CPP as it was with the auto, just to make sure.
I have a Haynes manual, but the diagrams in it are no good. They say I have to refer to the diesel manual.....
If I could just get my hands on a good set of complete diagrams for the engine and truck, I could start tracing out to see if the problem might be in the also be in the harnesses that I swapped out to go to the new manual.
I bought my paper shop manuals from Helm, but check this site out:
Diesel Technician Society
Looks like it's mostly engine related (being the Diesel Society), so I am not sure how helpful it'll be for the OP, but I think it's cool just the same.
In looking around, it looks like Ford might be restricting where you get this information. Not unusual for a manufacturer to do, but it sure stinks when you are trying to repair the product they sold you!
Cuda Jim, Do you have a diagram that shows the wire harness from the manual tranny up to and including the harness it plugs into on the front fender well? The harness on the fender has 2 plug ins that the auto tranny harness plugged into, but now one is empty because the manual tranny harness only has one plug. I want to see where the now empty plug goes to.
