which spark plug is best?? - Ford Truck Enthusiasts Forums
Old 04-21-2010, 07:15 PM
Shanemh Shanemh is offline
Shanemh is starting off with a positive reputation.
My truck seems to be missing a little when it is idling, so I am just gonna replace the spark plugs to try solve this as it has been around 3 yrs since I had them done last.
I have been looking at the various plugs available but there is so many out there, ranging in price from about $2.99 to $29.99.
Does anyone have any suggestions about what is the best set to get for the price, and why is there such a difference in price of some plugs.
Thanks.
Old 04-21-2010, 08:10 PM
KevinGnWV's Avatar
KevinGnWV KevinGnWV is offline
The village idiot.
KevinGnWV has a good reputation on FTE.KevinGnWV has a good reputation on FTE.KevinGnWV has a good reputation on FTE.
Cheap Motorcraft or Autolite is all you need. Anything else and your wasting $$ in my opinion.
Old 04-21-2010, 08:19 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
motorcraft copper.
or autolite copper.
or ngk copper.
Old 04-21-2010, 08:44 PM
jade79 jade79 is offline
jade79 is gaining momentum as a positive member of FTE.
I've always used regular old Autolites in both my 79 and 95. No complaints or problems. I always put a fresh set in when I do my yearly tuneup.
Old 04-21-2010, 09:38 PM
fishforlife2007's Avatar
fishforlife2007 fishforlife2007 is offline
fishforlife2007 is starting off with a positive reputation.
autolite copper. its what i run, along with many other members. dont have anything bad to say about them.
Old 04-21-2010, 10:15 PM
DreadyDiggs's Avatar
DreadyDiggs DreadyDiggs is offline
DreadyDiggs is starting off with a positive reputation.
I've got Motorcraft coppers in mine. Yanked Autolites out of it. I'd put in either. Stick with coppers.
Old 04-21-2010, 10:52 PM
Spark plug wires?
What about spark plug wires?
Any recommendations?
Old 04-21-2010, 10:54 PM
SaikotikGunman's Avatar
SaikotikGunman SaikotikGunman is offline
SaikotikGunman is gaining momentum as a positive member of FTE.
Autolite 25's in my 302, two bucks a piece, give or take. Cheap copper plugs are as good as it gets for these V8's.
Old 04-21-2010, 10:55 PM
mprice mprice is offline
mprice is starting off with a positive reputation.
I was mostly happy with the Beldens I got from NAPA for my last tuneup. The only thing extra I would have wished for was to have the wires numbered. That said they were a very good quality part for a daily driver at a reasonable price.
Old 04-22-2010, 05:11 AM
Old Hickory's Avatar
Old Hickory Old Hickory is offline
Old Hickory is gaining momentum as a positive member of FTE.Old Hickory is gaining momentum as a positive member of FTE.
Motorcraft or Autolites are the best for Fords.
Old 04-22-2010, 05:32 AM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
I like autolites , even ran them in my chevys back in the 70s....Lew
Old 04-22-2010, 06:31 AM
Uncle Grumpy Uncle Grumpy is offline
Uncle Grumpy is starting off with a positive reputation.
I've used NGK's in every vehicle for the last 20 years without trouble. Check with rockauto.com they have plugs as cheap as .70c sometimes.
I have a set of SMP Premium plug leads on my f150 and I use bosch on all my cars.
Old 04-22-2010, 02:13 PM
ive got the taylor streetfire wires on my 300. i think they are like 8.2mm wires? either way they do the job. taylor makes and excellent product.
Old 04-22-2010, 02:57 PM
ymeski56's Avatar
ymeski56 ymeski56 is offline
Der Postmeister
ymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputationymeski56 has a superb reputation
Motorcraft coppers & MDS 8.5 Supercoductor wires. Best wire specs & really last! About $70. but worth it. Especially if your running a 48 or 60K coil!
Double Plat plugs require more resistance to be overcome to initiate spark & make/leave too much heat in the combustion chambers. They don't like their gap stretched & surely don't accommodate side gapping. And I like to look in on my plugs more than once every 50-100K anyway. Also Coppers allow more base timing advance. I run a sidegap Motorcraft Copper at .056 gap (.044 is stock), 16 BTDC base timing w/ 87 octane gas. I can't do that w/ double plats w/o ping! Supercoductor wires, brass C & R, 60K (.45 ohm) HV coil. 87' 302 w/87k. 23mpg@65mph. Otherwise stock except K&N drop in filter & all fluids are Synthetic.
Old 04-22-2010, 03:22 PM
TorqueKing's Avatar
TorqueKing TorqueKing is offline
TorqueKing is gaining momentum as a positive member of FTE.
Another vote for Autolites. NGK coppers are nice too, but you can get Autolites anywhere.
For wires, I like the Bosch wires that Autozone sells.
Make sure your cap and rotor are the brass-insert kind. The regular zinc-contact cap and rotor are much cheaper but will corrode like no other!
New truck Masbutch 1999 to 2016 Super Duty 4 07-17-2016 04:28 PM
Does a 99 5.4 engine have spark plug breaking/freezing problem? coolfeet 1968-2013 Full Size Vans 36 09-29-2014 09:08 AM
99 f250 2v 5.4l plug torque specs? joe_r_dog Modular V8 (4.6L, 5.4L) 2 01-03-2012 06:49 PM
BEST SPARK PLUGS FOR 1998 F150 4.6? robjs111 1997 - 2003 F150 11 07-19-2010 01:45 AM
v-10 spark plugs and coil packs 72soa 1968-2013 Full Size Vans 2 03-02-2008 02:26 PM
Tags
302, 351m, advantage, copper, core, double, f150, ford, load, mds, ping, platinum, plug, plugs, spark, sparkplugs, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
