Factory tach wiring questions.
Old 04-21-2010, 04:44 PM
scottscott's Avatar
scottscott
scottscott is offline
I have a question about the factory tach.
1. When adding the tach cluster to a truck that didn't have a tach originally, do I have to run new wires to the tach, or are they already in the harness????
In the factory manual, it says the same tach works for 6 or 8 cylinder engines. An extra wire is hooked up on the 8 cylinder tach to calibrate it. Very interesting!
I read the tach tips in the tech section, it was very helpful! Thanks, Scott
Old 04-21-2010, 04:53 PM
stylin86f150's Avatar
stylin86f150
stylin86f150 is offline
I would also like to know the answer to this because the cluster i have now has a tach and my truck originally didnt have one
Old 04-21-2010, 05:37 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
All you ever wanted to know about factory tach's, and then some:
https://www.ford-trucks.com/forums/9...-question.html
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
The tach cluster is plug and play. No wiring needed. You may have to add the jumper wire like you said for a six or 8 cylinder though.
Old 04-21-2010, 07:05 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
Normally the jumper wire isn't needed, however if there have been engine swaps, and the "Ignition harness" wasn't changed with the engine, then a jumper wire or cutting the 8 ground wire for V8 calibration is nessecery.
Old 04-22-2010, 01:57 PM
TheKirbyMan's Avatar
TheKirbyMan
TheKirbyMan is offline
Everything should work as long as your factory wiring is working properly. If not, it's possible to wire the tach yourself, pretty much just like you'd wire up an aftermarket tach.
As you can read in that topic, I had quite a bit of trouble getting my tach to work. I wasn't getting power to the tach through the circuit film, so I ended up having to run a new wire to the B post (main power terminal on the tach) that's on with the key in ACC or RUN. Worked a charm, all the other factory wiring handled everything.
Old 04-22-2010, 04:08 PM
scottscott's Avatar
scottscott
Thanks for the help!!!!!
CB3
05-24-2017 10:40 PM
rowdyredneck
08-03-2013 10:45 AM
quakerj
06-27-2013 12:27 PM
Nero Morg
07-31-2012 10:44 PM
topscrt
02-09-2009 09:47 PM
Quick Reply: Factory tach wiring questions.
