Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 04-21-2010, 01:21 PM
Taboo Taboo is offline
Garage is empty, add now
Taboo is starting off with a positive reputation.
'10 Expy Spark Plugs, Still a Problem?
Just wondering if the 2010s have the same spark plug removal issues as the earlier models. If so I'd like to know so I can pull them now and reinstall with some anti-sieze. Any thoughts?
Thanks!
  #2 (permalink)
Old 04-21-2010, 09:08 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
no
In 2007 Ford revised the heads/plugs to a traditional 1 piece plug
all 2008+ 4.6 3v and 5.4 3v motors are now fixed
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #3 (permalink)
Old 04-22-2010, 07:57 AM
Thanks Tylus... that's good to know. Having read all of the posts regarding that issue I was hoping Ford had actually done something to correct it. I also have a '04 Expedition with the 2v 5.4. Haven't attempted to change the plugs on it but feel it's time with 85K on the odometer. Do the two valve engines have the same issue?
Thanks again for the help!
  #4 (permalink)
Old 04-25-2010, 05:26 PM
poppie poppie is offline
poppie is starting off with a positive reputation.
We all knew about the blowout problem on the 2 valve 5.4's,I thought that problem was fixed when the 3 valve 5.4 came out with MORE threads per plug BUT that MADE a problem trying to change the plugs and having them break off,something about the threads being below the bottom of the head and carbon/soot building up on the bottom of the plugs causing them to bind up in the head on the way out,what's the story now?????.
__________________
2002 F350 4 door Dually XLT lariat PSD Crew Cab 4R100 4.10 VDH4 Prepump, In-Tank, Crossover,Tymar air intake, Edge Evolution, Magellan 6000T GPS, White Night backup light's, DPPI Guages, Walker "Big Truck" Muffler, b&w turn over hitch, pulling a 2004 sunnybrook 31 bwks with 3 slide's, truck & RV 20,900 #'s all at the scale .
My truck and 5er.
  #5 (permalink)
Old 04-27-2010, 01:34 AM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
here is the lowdown on the spark plugs from about 2000 to current
2000-2003
4.6 2v
5.4 2v
V-10
problem seemed to surface when Ford started using the PI heads. spark plugs ejected from the head due to insufficient threads in the head. repairs required either a heli-coil or insert...or a new head.
it's completely random and can happen to anyone. Some people never have it happen...and some poor *******s have it happen one after another
2004-2007(midyear)
4.6 3v
5.4 3v
spark plugs are a multiple piece design that is tack welded together. Ford also increased the threads inside the head to fix the blow-out issue...the nature of the 3v head made for an extremely small space where the plug penetrates the cylinder
carbon from the ignition process and unburnt fuel collects around the spark plug. this causes the spark plug to get caught. the tack weld breaks and the plug will come out in 2-3 pieces.
doesn't always happen...but it's a definite possibility
2008-current
4.6 3v
5.4 3v
in late 2007 Ford issued a redesigned head that went back to a traditional sparkplug.
motors built after Nov 2007 have the new design head. So if you are looking at a 2008 model Ford, you need to look at the drivers side head. it will have a build date sticker on there. You want one built after the revision was issued.
__________________
  #6 (permalink)
Old 04-27-2010, 07:56 AM
Thanks tylus... that's good info. It looks like I'm okay with the '10, not so much with the '04.
Tags
10, 2010, 54, cab, change, el, expedition, ford, fords, issue, plug, plugs, problems, pull, spark, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
