Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > Maryland Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Maryland Chapter Join Chapter, Leader: jr32560
  #1 (permalink)
Old 04-21-2010, 09:19 AM
Pasadena F-250 Pasadena F-250 is offline
Garage is empty, add now
Pasadena F-250 is starting off with a positive reputation.
I think its Electrical? Can you help?
I have an issue with my 03 F-250 5.4Liter. I think it might be electrical. The truck will not go into reverse it makes a grinding sound like the parking dog is not totally disengaging, it will go into drive but sometimes when you let off the gas it makes the same rubbing/grinding sound but not as severe. Also the 4x4 will not work it will not even attempt to go into 4x4 high or low no lights come on or anything. Also when you turn the key into the acc power position the ABS kicks on for a second. This all started after i washed and degreased under the hood of my truck. is there a connection in the wiring harness under the hood that may have a common connection to the 4x4, ABS,or transmission if so what connection is it. i am going to pull all the plugs apart and inspect for water or other damage? The truck is in excellent shape and only has 55,000 miles on it.The tranny fluid is good and the linkage looks ok. again this happened suddenly after washing under the hood of the truck, with no prior warning or issues. any suggestions or advice??
  #2 (permalink)
Old 04-21-2010, 10:46 AM
Surge08's Avatar
Surge08 Surge08 is offline
Just a Damn Number
2004 Ford F-350
My Garage
Surge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to behold
Nevermind........
__________________
Chris
2004 F350 XLT 4x4 6.0L SC/LB 4x4
1998 Explorer Sport 4x4 4.0L
I am just a number and no I don't care about Trophy's
  #3 (permalink)
Old 04-21-2010, 04:18 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Old-Timer
2005 Ford F-250
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
As I tried to answer your problem on the phone, I won't repeat it here....just stop by and tell us what fixed it! OR if you needed an excuse to buy a new truck..... you got it!
__________________
BPofMD - Bud - USN-Actively Retired
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB Crew-cab Arizona Beige / Blue Spring / Gauges / Coolant Filter / SG-II / Peragon Bed Cover/ P/S Filter/ MAG-HYTEC differential cover/
2007 Arctic Fox 30' Fifth Wheel -2012 VW Passat SE TDI (An ALL-DIESEL family)
Join the Maryland Chapter click HERE
  #4 (permalink)
Old 04-21-2010, 05:42 PM
BPofMD's Avatar
Old-Timer
2005 Ford F-250
Ok...just talked to him on the phone..... it was the two relays under the hood....they filled with water from him spraying in there. Once he pulled the relays, he said water poured out of the connection. Auto Zone only had two relays in stock and he got them. Once plugged in, everything started working...once he reconnected the ground lead to the battery.
I had told him it HAD to be a blown fuse or a bad relay.... I was wrong...it was TWO shorted repays.
__________________
  #5 (permalink)
Old 04-21-2010, 05:53 PM
jr32560's Avatar
jr32560 jr32560 is offline
Maryland chapter LDR
jr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to behold
way to go Bud-good looking out~~~~
__________________
Junior Hardy-
1990 F150 302
1995 E250 4.9
member of the Boy you ain't Right club #4
President of the crap shooters club
  #6 (permalink)
Old 04-24-2010, 04:39 PM
Bad Cap install
What must have happened was when the cap was installed in my truck they ran a wire behind that relay box for the cap light and they clipped it back on upside down so all the water collected in the relay casing instead of just running off. im glad i found out the way i did instead of being camping up in the mountains and had it happened there.
  #7 (permalink)
Old 04-24-2010, 05:10 PM
BPofMD's Avatar
Old-Timer
2005 Ford F-250
That sucks!!! But you are right!!! MUCH better now than such as you say! You'd better hope they did not do any more 'modifications' !!!!
__________________
Tags
2003, f250, grinding, making, reverse, sound, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
