bronco emission vac line diagram - Ford Truck Enthusiasts Forums
Old 04-21-2010, 04:11 AM
JJ98 JJ98 is offline
JJ98 is starting off with a positive reputation.
hay whats up i was wondering if any of you guys had a pic of a 90 ford bronco emission line digram trying to help a buddy out 5.8 liter if so thanks also any place you know of to get the hole vacum line kit
Old 06-02-2010, 06:17 AM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
Is there a diagram in the engine compartment?
Maybe you could just order the vacuum line and fittings, they should be a standard size. I think mechanics replace them all the time because they wear out and leak.
Let's bump it and see if anyone has a comment.
Old 06-02-2010, 06:23 AM
b4hntn b4hntn is offline
b4hntn is gaining momentum as a positive member of FTE.b4hntn is gaining momentum as a positive member of FTE.
The one on my hood was difficult to read so I took a digital picture. That makes it easy to read. However, mine is a 1994. Have you checked the hood sticker?
Putting a rear tank in a 97 f150 justforkicks 1997 - 2003 F150 5 10-26-2013 03:04 AM
84 bronco fullsize 351w emissions removal please help Ryan Hankins 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 08-17-2013 08:59 PM
93 bronco won't pass emissions dallas lewis 1978 - 1996 Big Bronco 3 01-12-2006 06:28 PM
78' emissions sticker marspenc 1978 - 1996 Big Bronco 3 04-30-2003 10:12 PM
Emissions vacuum lines TallPaul Ford Inline Six, 200, 250, 4.9L / 300 9 03-08-2001 06:50 AM
Tags
1978, 400, 54, 99, bronco, chat, diagram, emission, emissions, expedition, ford, hose, line, ltr, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
