Need advice on 3-point seat belt
Old 01-18-2012, 11:35 AM
BigMikeUGA's Avatar
BigMikeUGA
BigMikeUGA is offline
I used Charlie's write up when I did my 3pt belts and it worked out great. I will say though that with the headliner already removed, I was able to reach my big paws behind the corner piece from the top and just hold it in place to rivet it.
Old 01-18-2012, 06:19 PM
pburress's Avatar
pburress
pburress is offline
Looks great!
Old 07-12-2012, 01:08 AM
David LaPell's Avatar
David LaPell
David LaPell is offline
I have a 74 F-100 that I want to put 3 point belts in, I am hoping it is a similar set up to get them in the truck. Right now its at the shop getting the motor finished up. What kind of belts did you use? I see a set from LMC for $200 for both, but I want to make sure I am getting the best set for the money, not just cost wise but safety wise too, my son will be riding in it and I want everything as strong as possible.
Old 12-07-2012, 02:33 PM
davecycleman's Avatar
davecycleman
davecycleman is offline
I dug up this old thread while searching for help installing seat belts in my '61. I was hoping to find out what 3 point belts you started with. Also, it was stated that the floor mounting position had to be correct and I was hoping for photos of the bottom mounts.
Any help would be appreciated.
Thanks,
Dave
Old 12-07-2012, 11:16 PM
Macs1964F100's Avatar
Macs1964F100
Macs1964F100 is offline
Thank y'all for the thread. I installed 3 lap belts in my 64 after I purchased it because I did not think there was a 3 point option. I will put the the 3 point seat belts at the top of my upgrade list.
Old 12-08-2012, 09:27 AM
charliemccraney's Avatar
charliemccraney
charliemccraney is offline
The belts I used are Autoloc.
I see from an earlier post in this thread that I'm suppose to post pics of the lower mounting points. I'll try to remember to do that. At best, these pics will be for reference. Different seats may require different anchor positioning so don't assume that you need to put yours in the exact same spot as mine. The same goes for the 3rd point, if you're taller, it will need to be higher in that panel.
Old 12-14-2012, 04:58 PM
davecycleman
I would be interested in photos of the mounting points. I haven't purchased the belts yet but I have been looking online and checked out Wesco Performance. You can order mounting kits with their 3 point belts with a mounting plate that looks a lot like the one in the tutorial.
Dave
Old 05-16-2013, 06:47 PM
charliemccraney
Better late than never, right?
Driver side
Size:  107.9 KB Name:  m_IMG_7736_zps7f5265bc.jpg
Size:  125.4 KB Name:  m_IMG_7732_zps5694337b.jpg
Passenger side
Size:  116.7 KB Name:  m_IMG_7738_zpse5e0bc3f.jpg
Size:  115.4 KB Name:  m_IMG_7734_zps2a072ecc.jpg
Old 12-26-2013, 09:53 AM
Ki-Adi-Mundi's Avatar
Ki-Adi-Mundi
Ki-Adi-Mundi is offline
Charliemccraney:
Where online did you get those gold reinforcement plates for the top?
Thanks
Old 12-26-2013, 01:01 PM
charliemccraney
I think I got them here.
https://www.gotbelts.com/
Old 12-26-2013, 01:53 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
Thanks Charlie for the great write up. I will need to do this soon.
Old 12-26-2013, 04:24 PM
Ki-Adi-Mundi
This has been a wonderful write up thanks! I am about to order mine from wesco performance. Of y'all that have used them what are your thoughts ?
  #28
Old 12-30-2013, 07:12 PM
66F250CS's Avatar
66F250CS
66F250CS is offline
Charlie, I followed your instructions about a year ago and the install worked perfectly on my 66 F250. It was a little tighter on the driver side floor because of the fuel line, but it all worked perfectly. We have luckily not had to test them, but it gives me a great sense of peace when I drive. My 66 Mustang has only lap belts and I'm always afraid I'll be tossed through the window. I think I picked up my belts from LMC but I saw the same ones at a local speed shop (So-Cal). I found that the lap portion of the belt (the female end) is a tiny bit too long, but it still works well
  #29
Old 03-27-2014, 06:10 PM
Ki-Adi-Mundi
For the part going into the cab corner, Is the purpose of the rivots just to hold the reinforcement plate in while the bolt is screwed in? Or is it also there for any structural help?
Thanks
  #30
Old 03-27-2014, 06:17 PM
66F250CS's Avatar
66F250CS
66F250CS is offline
Thanks
Just there to hold the plate in place. To weak for structural support.
Quick Reply: Need advice on 3-point seat belt
