Need advice on 3-point seat belt - Page 2 - Ford Truck Enthusiasts Forums
Old 01-18-2012, 12:35 PM
BigMikeUGA BigMikeUGA is offline
BigMikeUGA is starting off with a positive reputation.
I used Charlie's write up when I did my 3pt belts and it worked out great. I will say though that with the headliner already removed, I was able to reach my big paws behind the corner piece from the top and just hold it in place to rivet it.
Old 01-18-2012, 07:19 PM
pburress's Avatar
pburress pburress is offline
pburress is starting off with a positive reputation.
Looks great!
Old 07-12-2012, 02:08 AM
David LaPell David LaPell is offline
David LaPell is starting off with a positive reputation.
I have a 74 F-100 that I want to put 3 point belts in, I am hoping it is a similar set up to get them in the truck. Right now its at the shop getting the motor finished up. What kind of belts did you use? I see a set from LMC for $200 for both, but I want to make sure I am getting the best set for the money, not just cost wise but safety wise too, my son will be riding in it and I want everything as strong as possible.
Old 12-07-2012, 03:33 PM
davecycleman davecycleman is offline
davecycleman is starting off with a positive reputation.
I dug up this old thread while searching for help installing seat belts in my '61. I was hoping to find out what 3 point belts you started with. Also, it was stated that the floor mounting position had to be correct and I was hoping for photos of the bottom mounts.
Any help would be appreciated.
Thanks,
Dave
Old 12-08-2012, 12:16 AM
Macs1964F100's Avatar
Macs1964F100 Macs1964F100 is offline
Macs1964F100 is starting off with a positive reputation.
Thank y'all for the thread. I installed 3 lap belts in my 64 after I purchased it because I did not think there was a 3 point option. I will put the the 3 point seat belts at the top of my upgrade list.
Old 12-08-2012, 10:27 AM
charliemccraney charliemccraney is offline
charliemccraney is gaining momentum as a positive member of FTE.charliemccraney is gaining momentum as a positive member of FTE.
The belts I used are Autoloc.
I see from an earlier post in this thread that I'm suppose to post pics of the lower mounting points. I'll try to remember to do that. At best, these pics will be for reference. Different seats may require different anchor positioning so don't assume that you need to put yours in the exact same spot as mine. The same goes for the 3rd point, if you're taller, it will need to be higher in that panel.
Old 12-14-2012, 05:58 PM
I would be interested in photos of the mounting points. I haven't purchased the belts yet but I have been looking online and checked out Wesco Performance. You can order mounting kits with their 3 point belts with a mounting plate that looks a lot like the one in the tutorial.
Dave
Old 05-16-2013, 07:47 PM
Better late than never, right?
Driver side
Passenger side
Old 12-26-2013, 10:53 AM
Ki-Adi-Mundi Ki-Adi-Mundi is offline
Ki-Adi-Mundi is starting off with a positive reputation.
Charliemccraney:
Where online did you get those gold reinforcement plates for the top?
Thanks
Old 12-26-2013, 02:01 PM
I think I got them here.
https://www.gotbelts.com/
Old 12-26-2013, 02:53 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Thanks Charlie for the great write up. I will need to do this soon.
Old 12-26-2013, 05:24 PM
This has been a wonderful write up thanks! I am about to order mine from wesco performance. Of y'all that have used them what are your thoughts ?
  #28
Old 12-30-2013, 08:12 PM
66F250CS's Avatar
66F250CS 66F250CS is offline
66F250CS is starting off with a positive reputation.
Charlie, I followed your instructions about a year ago and the install worked perfectly on my 66 F250. It was a little tighter on the driver side floor because of the fuel line, but it all worked perfectly. We have luckily not had to test them, but it gives me a great sense of peace when I drive. My 66 Mustang has only lap belts and I'm always afraid I'll be tossed through the window. I think I picked up my belts from LMC but I saw the same ones at a local speed shop (So-Cal). I found that the lap portion of the belt (the female end) is a tiny bit too long, but it still works well
  #29
Old 03-27-2014, 07:10 PM
For the part going into the cab corner, Is the purpose of the rivots just to hold the reinforcement plate in while the bolt is screwed in? Or is it also there for any structural help?
Thanks
  #30
Old 03-27-2014, 07:17 PM
66F250CS's Avatar
Quote:
Thanks
Just there to hold the plate in place. To weak for structural support.
1967 f100 install 3-point seat belt? carbo_nero 1967 - 1972 F-100 & Larger F-Series Trucks 9 02-14-2017 12:14 AM
3 Point belt upper location lasermike 1973 - 1979 F-100 & Larger F-Series Trucks 0 09-23-2016 11:24 PM
2006 Extended cab seat/seat belt questions. Kaslothedog 1999 to 2016 Super Duty 0 09-17-2016 06:59 PM
3 point seat belts Cpsorlando 1973 - 1979 F-100 & Larger F-Series Trucks 10 08-04-2015 02:52 PM
Shoulder belts in a fridge theodore/teddy 1957 - 1960 F100 & Larger F-Series Trucks 3 12-30-2011 11:32 PM
Tags
1979, 1983, 3point, belt, belts, f100, f150, ford, mount, point, removing, seat, seatbelt, seatbelts, set, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
