Warranty data plate decode please...
Here is the info.
F250CR404057
WB, 122
Color, M
Model, F250
Body, 81B
Trans, F
Axle, 24
GVW, 7400
HP, 135
RPM, 3800
dso, 75?
here is a link to the pictures i took this morning....
63 custom cab pictures by wwilsonpaints - Photobucket
Thanks.
F250CR404057
WB, 122
Color, M
Model, F250
Body, 81B
Trans, F
Axle, 24
GVW, 7400
HP, 135
RPM, 3800
dso, 75?
Thanks.
The VIN has too many digits (12), it should have 11. Eliminate the zero, it doesn't belong there.
F25 = F250 2WD
C = 292 2V
R = San Jose CA Assembly Plant.
404057 = 1963, assembled April 1963.
122" Wheelbase.
M = Corinthian White
F250 2WD / 7400 lbs. GVWR
81B = Custom Cab.
F = Borg Warner T-98 4 Speed Manual Transmission.
24 = Dana 60 / 4.56-1 / non Limited Slip / 5200 lb. Rear Axle Capacity.
7400 lbs. Gross Vehicle Weight Rating.
135 net HP @ 3800 RPM
75 = Phoenix AZ Ford District Sales Office, where the original selling dealer ordered the truck from.
btw: The AM radio and the bezel is from a 1962/63 Fairlane. The A/C is aftermarket. The Holley carb & air cleaner (mebbe the entire engine) is from a 1961/64 C Series Tilt Cab or F700.
Sad to say, that isn't a 1957 Ford/T-Bird carb & 4V manifold.
Dunno, but it's nothin' special, all the trucks using this bed have the same feature.
B7D9927701A .. Left Quarter Panel-includes wheelhouse.
Fits: 1957/60 F100/350 118" wheelbase / 1961/63 F100/250 120" & 122" wheelbase / 1964/66 F100/250 120" wheelbase.
F25 = F250 2WD
C = 292 2V
122" Wheelbase.
81B = Custom Cab.
Originally Posted by Bill W
Why is the inner fender shaped this way on the drivers side?
F25 = F250 2WD
C = 292 2V
122" Wheelbase.
81B = Custom Cab.
btw: The AM radio is from a 1962/63 Fairlane. The A/C is aftermarket. The carb & "party hat" air cleaner (mebbe the entire engine) is from a C Series Tilt Cab or an F700 or larger truck.
F25 = F250 2WD
C = 292 2V
122" Wheelbase.
81B = Custom Cab.
Thank you Bill!
If the engine has been changed out would it still be a 292?
Prolly, and if it's from an F700 and etc, it's a 292 Heavy Duty w/sodium valves.
BTW.... both headlights have a fomoco emblem right in the center? original maybe?
Original and desireable...even if they don't work.
One last question, the tool box would have been put in after the fact. Correct?
Most likely, prolly by a dealer, but...it is Gen-U-Ine Ford, and was originally an option on 1964/66 F100/250 2WD & 1966 F100 4WD short bed Stylesides.
Or is it F O R D in raised block letters? Block letters were used 1956/59, Ford in an oval 1960 thru circa 1968.
Whatever they are, they are VERY desirable, haven't been available since the late 1960's.
Ford in an oval: They're the same as: 1965/68 Mustang's, Cobra's, GT350's & GT500's, plus other 1960 and later FoMoCo vehicles w/single headlamps.
If they have F O R D in block letters, some 1956/57 T-Bird nut will pay big bucks for them.
btw: I edited in (so what else is new?) the bed info in post #3.
What does the headlamp emblem look like, Ford in an oval? If so...is it etched into the glass, or a transfer?
They are etched. i will put a battery in it and see if they work or not.
Bill W
44
03-19-2015 04:48 PM
Bill W
09-02-2012 11:10 AM
