Bent Rear Axle? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Bent Rear Axle?
Old 04-20-2010, 12:33 PM
ke7gpu ke7gpu is offline
ke7gpu is starting off with a positive reputation.
Bent Rear Axle?
I have a ’99 F250 SD 4X2 and I got hit the other day by a hit and run; guy ran a stoplight and smacked my truck then took off. Luckily he hit he square on the rear passenger tire and there was no body damage and all it did was scratch my rim a little and blow the tire, or so I thought...
Later I noticed that when I get up to around 60mph the truck gets a little squeamish. When I turn at all like to change lanes or something it feels like my back end is following me like a trailer, like it is delayed and the back end sways a little bit. It doesn’t vibrate or anything like that and no noises… It isn’t super bad but it worries me
I jacked up the back end and spun the tires to see if there was a wobble and there isn’t one on either tire. So I took it to an alignment shop and they said that the rear thrust angle is 1.02* to the left and that there isn’t any adjustment for the back so they couldn’t do anything about it. I asked what would be the cause and they said either a bent axle or the frame is bent.
So two questions, how do I figure out which of the two it is? And second, does this sound right or could there be any other causes/fixes?
Insurance said they won’t do jack because I have liability only and I didn’t report it to insurance the same day as the accident so I guess I am on my own...
Old 04-20-2010, 12:51 PM
mwsF250 mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
Sorry to hear about this.
The rear thrust angle means the axle is not perpindicular to the centerline of the truck.
While a bent frame is possible, they are so beefy it seems unlikely.
I'd think it is more likely that something else is bent or shifted. Spring hanger? Shackle? Axle shifted on it's mount?
What you need is to find someone experienced and caring enough to actually take the time and look at things and take measurements and figure out the root cause. A quality suspension/alignment shop.... Definitely won't be the discount or high school flunky hiring chain shops!
Paying a respectful amount to get careful and true root cause analysis is the best solution.
Old 04-20-2010, 03:26 PM
wizardsr's Avatar
wizardsr wizardsr is offline
wizardsr is gaining momentum as a positive member of FTE.wizardsr is gaining momentum as a positive member of FTE.
Spot on, couldn't have said it better myself!
Get it to a good shop who can figure out what's bent. If the wheels don't wobble and there's no shake on the highway, you didn't bend an axle. The housing is stout, no worries there. The frame is fairly stout; it's possible the frame is bent, but unlikely. Most likely a bent shackle or spring hanger as those are the weak links.
Old 04-21-2010, 08:02 AM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
A couple of things. 1 degree isn't a whole lot, and I don't think it'll cause what you feel. The impact might have broken the leaf spring pin that aligns the leaf spring pack to the axle.
What are the tire pressures like? Did you check them after the accident? Maybe that tire is losing air?
Also, jack the rear wheels off the ground and pull them in and out - the impact may have broken something in the wheel bearing/spindle/hub.
Old 04-27-2010, 05:56 PM
Well it actually blew the tire and I had it replaced. I have taken apart both wheels and can't see any damage and I don't notice anything bent... I found shop that laughed when I told them that Pepboys said they didn't know what was causing the rear tire alignment to be off. They said that they wouldn't have any problem with telling me what is bent.
They did say that one degree is "in the red" or considered to be out of an acceptable range and that I would feel it but IDK....
Ill let you know when I get it fixed...
Old 06-27-2010, 05:36 PM
dbracing dbracing is offline
dbracing is starting off with a positive reputation.
Did you ever figure out what was wrong? I'm experiencing the same thing. the truck has been back to the dealer several times to no avail.
Old 06-28-2010, 12:07 AM
I have not figured it out yet. I took it one other place but they could not help me. But honestly I have not had much time to work on it much and it hasn't been enough of an issue to keep me from using it when I need it since it is not my daily driver...
I will be sure to post back when I have more information.
Old 06-28-2010, 05:46 AM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
You do have uninsured motorist insurance, right? Most states require you carry that coverage. It usually has a low or even no deductible.
Old 06-28-2010, 05:57 AM
mrford60's Avatar
mrford60 mrford60 is offline
mrford60 is starting off with a positive reputation.
just an easy quick frame check, look at the gap between the bed and the cab on both sides, have they changed? and look at the gap between the bumper and the bed. they should be about the same, if they are majorly different you should goto a body/frame shop and get it checked out. good luck. you should have called the police at the time of the accident.
Old 08-09-2012, 07:05 AM
drgnner drgnner is offline
drgnner is starting off with a positive reputation.
Im new to this forum. 06 F-250 SD. For tens of thousands of miles, I have tried to figure out the vibration on l/s rear at 45-50 mph. Re-balanced tire smoothed it out some, but it is always there. The left rear brake squeals when brake is applied.
I have not over loaded the suspension. I did set my superchips controller to full power once just to see what it did and experienced a wonderful hole shot in 4x4 ... one time only.
Im thinking I twisted the axle after reading this forum. Any thoughts?
Old 02-19-2014, 03:04 PM
jimcb1 jimcb1 is offline
jimcb1 is starting off with a positive reputation.
did they ever find what was bent
Old 06-14-2015, 08:01 PM
IHateCommieCars's Avatar
IHateCommieCars IHateCommieCars is offline
IHateCommieCars is gaining momentum as a positive member of FTE.
Quote:
I was scrolling down the thread to see if anyone brought this up.
In the event you describe, the type of insurance you have, or even if you have no insurance, doesn't matter. The other driver is at fault. Their liability insurance pays for the damage to your car, and probably rents a car for you to drive while yours is getting fixed. You have no deductible, co-pay, or any thing.
You don't even need or want to call your insurance company. It's best if they know nothing about it. You contact the at-fault driver's insurance company. They should send you a check for the full amount of the repair costs.
Old 06-14-2015, 08:14 PM
AKHunter93's Avatar
AKHunter93 AKHunter93 is online now
AKHunter93 has a good reputation on FTE.AKHunter93 has a good reputation on FTE.
He said in the OP that it was a hit and run. He had no way of contacting the other driver's insurance company, because the other driver didn't stick around to give him that information.
Also, this was five years ago.
Old 06-14-2015, 08:39 PM
Well, that was stupid of me to post. I forget to look at the date on these threads when I search for relevant topics.
Old 06-14-2015, 08:57 PM
AKHunter93's Avatar
I think most do it more than we'd like to admit
Christmas Epistle 2016 jniolon 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 12-17-2016 07:20 PM
96 Stroker Rear Ended in Berkeley powrstrkr 1994.5 - 1997 7.3L Power Stroke Diesel 69 08-06-2016 09:57 PM
Ugly Betty: Frame-Up Rebuild w/ a Donor tschrubb 1987 - 1996 F150 & Larger F-Series Trucks 225 08-13-2014 01:33 PM
F150 5.0 or F250 6.7 - Advice needed??? Evader53 1999 to 2016 Super Duty 4 02-17-2012 05:40 AM
Lets see pics of aftermarket body parts (Painted & installed). Blown 331 1973 - 1979 F-100 & Larger F-Series Trucks 5 09-02-2009 04:48 PM
Tags
150, 2006, alignment, axel, axle, bent, check, duty, end, ford, frame, housing, ranger, rear, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
