battery isnt holding a charge?
i bought a refubished battery and it last for about a week and yesterday when i came home from school i shut off the truck and tried starting it and wouldnt start..
possibly be voltage regular?
i swapped out alternators with another one..
let me know...!!!!
thanks!
let me know...!!!!
thanks!
If you're going to do electrical work, you absolutely need a multimeter. What you're doing is called "throwing parts at it" and is a waste of time and money. Use the right tools to diagnose the problem, and get it right the first time. A lot of people replace parts because "they're old anyway" or "it'll go bad eventually," those same people have more money in their truck than it's worth.
When you say "wouldn't start," does that mean it turns over but doesn't fire, or doesn't even turn over? Or turns over slowly?
thanks for the info..
although the problem was the voltage regular..
went and bought one for $10 and now iam good to go!
sorry if u thought i didnt know anything about mechanics and was going to waste my money on things i dont need. just not what i do! and very seldom i get out the multimeter for anything when i know what the problem is. oh well
You'll learn someday (16 and know it all), if you knew the answer, why'd you ask for opinions on here. The guys on here are here to help and give suggestions! Charging systems can get complicated, therefore if you use a multimete you can figure things out alot easier most times, hence not having to replace the alternator you changed out!
How much was it? Usually all they do is mix some Epsom Salt mixture and charge the battery and "hope" it holds.
Another thing, is it takes the battery 3-4 cycles to even "think" of keeping a charge (if it even does)
Just trying to help. A refurb was what? $20? A new-low budget battery would have been maybe $40? A good battery around $60.
Josh
Josh
"i wont have any carb, fuel questions anymore.. i already solved all my problems in that area and rebuilt my carb"
guess you'll never have to ask for any advice again. you know everything now.
someday you'll thank the guys on here for their words of wisdom, they are only here to help fellow ford enthusiasts!
breslijo
1997-2006 Expedition & Navigator
02-10-2006 03:47 PM
alpine7572
1997 - 2003 F150
10-30-2005 10:40 AM
NJ239Y
16
06-22-2005 05:15 PM
