E450 same as F450 brakes? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-20-2010, 08:16 AM
Catsailor Catsailor is offline
Catsailor is starting off with a positive reputation.
I have a 2004 E450 Super Duty stripped chassis (motorhome) and I want to DIY change front brake rotors and pads. Will I be okay to follow F450 2wd instructions? Also, I'm a bit confussed about which rotors to get... do they have a hub assembly attached? Or should they look like normal "top hat" rotors, with holes for the wheel studs to go through and a small allen head bolt for rotor placement?
Any other advice is appreciated.
Tom
Old 04-20-2010, 08:24 AM
Sarge261's Avatar
Sarge261 Sarge261 is offline
Sarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant futureSarge261 has a brilliant future
If you are buying front rotors it will include the hub too. You should also get the studs with them. I would get some new wheel bearings and you will need new seals too. Its pretty stright foreward:
Remove the 2 caliper retaining bolts
Support the caliper with a Bungee, or coat hanger, dont let it dangle by the brake hose
Remove the dust cap, cotter pin, retainer, then the nut.
Becareful not to let the outer bearing fall out if you are going to reuse it
Slide the rotor off
Reverse procedure to reinstall
Hope that helps,
Sarge
e450 brake rotors question headbanger990 1999 to 2016 Super Duty 0 03-09-2016 10:53 PM
08 450 Rear Brakes & Rotors Superduty450 1999 to 2016 Super Duty 6 07-04-2014 09:34 AM
f450 brakes & rotors jimcb1 6.7L Power Stroke Diesel 12 03-27-2013 09:05 PM
92 F450 rear brakes help. Fordranchero Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 06-25-2012 05:53 PM
Removing front rotors '90 F-450 2WD 10-lug 1986F350witha7.3 1987 - 1996 F150 & Larger F-Series Trucks 5 09-02-2010 12:26 PM
Tags
60, bearing, brakes, change, diesel, e450, f450, front, howto, intake, pads, rear, remove, rotors, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
