Dually sway bar size - Ford Truck Enthusiasts Forums
Old 04-19-2010, 07:47 PM
cwnorris cwnorris is offline
cwnorris is starting off with a positive reputation.
I've got a 2003 crew cab long bed dually, 4 wheel drive, automatic. I'm getting the thump that I've tracked down to the sway bar bushings. I put my caliper on the bars, and the front and back are both 1 1/16" (27mm). That seems a little small to me. Any other dually owners out there have bars that small? I talked to Energy Suspension, and I can piece together the parts to replace the bushings if I verify the end link size, but I wonder if larger sway bars would help with body roll.
I would think a 1 ton should have thicker bars, maybe 1 1/4"?
Thanks.
Old 04-19-2010, 08:45 PM
Franko72's Avatar
Franko72 Franko72 is offline
Molon Labe
Franko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud of
I haven't measured mine, but the both look like the same size and pretty small, I can get under it in the morning if need be.
Old 04-19-2010, 08:49 PM
Franko72's Avatar
Molon Labe
I Just measured them...Both front and rear are 1 1/16 like you stated.
Old 04-19-2010, 08:58 PM
Bigcat350's Avatar
Bigcat350 Bigcat350 is offline
Bigcat350 has a very good reputation on FTE.Bigcat350 has a very good reputation on FTE.Bigcat350 has a very good reputation on FTE.
That is funny I measured mine and they are 27mm. We make stabilizer bar's and we make 33-34 mm bars for a lot smaller trucks and even the Edge.
Old 04-19-2010, 09:08 PM
Thanks guys, at least I now know that somebody didn't grab a sway bar from a Ranger on a late Friday on the assembly line. I wonder why the small sway bars? I'm feeling a little emasculated, maybe a little sway bar envy of the guys with 1 1/4" bars. I might check around for some larger bars before I replace the bushings. I do get a fair amount of sway in the corners, but I also realize it's a heavy truck.
Old 04-19-2010, 09:15 PM
Bigcat350's Avatar
I don't think you will find a larger bar for it but you might. The 27mm had to be tuned for our trucks. Ford always does a lot of tuning sizes (larger/smaller) before they settle on a bar they check it for several parameters.
Old 04-19-2010, 09:43 PM
I guess it's reasonable to assume that the engineers knew what they were doing, so I'll leave it alone, and get new bushings.
Old 04-19-2010, 11:58 PM
gp49 gp49 is offline
gp49 is starting off with a positive reputation.
If you want a little thicker then 1 1/16" or even thicker then 1 1/4" why not go with a 1 1/2" diameter from Roadmaster.... It does wonders with heavy campers that some carry on the back of the 350's... (BTW, that's my next upgrade)
They also make a 1 1/2 front bar as well. If you want to try a slightly smaller one try Hellwig products they make bars in the 1 3/8" and smaller range, I think.
Old 04-20-2010, 01:08 AM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
My truck does not have a swaybar in the rear. I thought it was odd and can only determine that being a base model truck (don't even have overloads) that it didn't come with one. The truck still hauls like a bandit though. I have a gooseneck and a 5th wheel hitch in the back and it has handled everything I've ever loaded in there. Even a 38' jlg platform manlift. (yup, I put one of those in the bed)
Old 04-20-2010, 09:03 PM
dn29626's Avatar
dn29626 dn29626 is offline
dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.
Remember folks, Ford is in business to earn a profit.
There are parts that are designed undersized to wear out early OR not installed at the factory at all if the vehicle can perform safely. Ford wants the warranty to run out before you decide you need them so you will pay extra for parts.
While my truck was still under warranty i had several items added to the truck. My dealer was happy to order and install the parts because Ford paid him, but i had to specifically request each.
Remember, Henry Ford would visit salvage yards to learn what parts never sold. He then met with his engineers to redesign those parts to be replaced.
Sway Bar Link Arm Removal Issue... CliffM64 1999 to 2016 Super Duty 1 09-22-2016 11:41 AM
1989 F250 4x4 sway bar hawk48rq 1987 - 1996 F150 & Larger F-Series Trucks 1 01-18-2016 05:05 PM
Front sway bar bushings vettman 1973 - 1979 F-100 & Larger F-Series Trucks 1 12-08-2015 03:58 PM
Greaseable Sway Bar Bushings and End Links Chevmn56 1999 to 2016 Super Duty 20 07-26-2013 08:02 PM
E-Series sway bars ydaveitsu 1968-2013 Full Size Vans 5 06-24-2011 01:17 PM
Tags
116, 1999, 27mm, bar, bushings, dually, energy, f150, f250, ford, front, powerstroke, size, sizes, suspension, sway
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
