exhaust manifold vs headers - Ford Truck Enthusiasts Forums
Old 04-19-2010, 04:57 PM
dan&levi dan&levi is offline
dan&levi is starting off with a positive reputation.
Recently took my 79 F150 in for some exhaust work. Shop said the exhaust manifold on let side was leaking and needed to be fixed. I am told headers heat up the engine compartment more, don't last as long and tend to leak themselve. Are there performance manifolds for a 460 or would a guy be just as well off with OEM? thanks
Dan
Old 04-19-2010, 05:17 PM
77460f150's Avatar
77460f150 77460f150 is offline
77460f150 is starting off with a positive reputation.
I guess that depends on what you use your truck for. I bought and installed L&L headers for my 77 F-150 460 and wouldn't change anything. They have never leaked due to the thick flanges and have a lifetime warranty. I have no dyno #'s to prove the HP increase but I sure can tell the differance in the "seat of the pants" feel. They sound so much better than stock manifolds too. I ran stock manifolds for quite a few years and never had any trouble with them either but, I really like the headers better. The L&L headers are pricey but IMO worth it. I have a friend that had a pair rust out after about 5 years (small pin holes by the collector) and they sent him a new set free of charge. He just had to return the rusted out pair to them. you can get them through Bronco Grave Yard. Just my 2 cents!! -Ed
Old 04-20-2010, 09:55 AM
ecidemon ecidemon is offline
ecidemon is starting off with a positive reputation.
To me, $470 is cheap for headers. I paid nearly $1200 for my SLP longtubes for my transam. L&L look like a pretty good deal to me, I'll probably get them for my '76 if I decide to swap in the 460.
Old 04-20-2010, 11:18 AM
bmarkline's Avatar
bmarkline bmarkline is offline
bmarkline is starting off with a positive reputation.
Headers will improve performance, but will also not last as long due to rusting like stated above. Simply just thinner material than a cast manifold. But, if you have a set that is ceramic coated, they not only prevent said rust, but also are supposed to reduce engine compartment temp by about 250 degrees F. The reason headers tend to "leak" is that no one ever keeps check of the header bolts. They tend to loosen up due to the shrinking/ expansion of the metal from heat. I just make sure to re-torque mine every time I change the oil and never had any issues arrise. Another thing to think of though, aftermarket headers may not line up/ bolt up with your current exaust system.
Old 04-20-2010, 11:38 AM
My SLP's still looked like the day they were put in 4 years later, but they were coated.
I'm actually having a difficult time finding a good quality header for the 390, found a lot of cheap ones though.
Old 04-22-2010, 08:31 AM
Kalve's Avatar
Kalve Kalve is offline
Kalve is starting off with a positive reputation.
summit racing has some seen some on there for the 360 I have for under $300 you might want to check them out.
Old 04-22-2010, 09:00 AM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
I have headers on both my 74' and 04' trucks and wouldn't have it any other way. I hate exhaust manifolds. The headers on my 74' are over 10 years old and are steel. The ceramic coating on off the shelf headers is junk and rusts in short order. If you want a set of headers to last, get the painted version, strip the paint and smooth the welds. Then send them off to a reputable ceramic coating shop to get coated.
Exhaust manifolds to headers 4fords 1997 - 2003 F150 3 11-29-2015 09:49 PM
1983 Bronco EFi manifolds and Walker Y pipe dan240 Ford Inline Six, 200, 250, 4.9L / 300 2 11-11-2015 01:39 PM
warped exhaust manifolds blick 2004 - 2008 F150 15 08-06-2014 05:20 PM
Replace exhaust manifold or headers? 5280 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 04-19-2014 02:45 AM
Cracked manifold... Replace with headers? minnesotafisherman 1987 - 1996 F150 & Larger F-Series Trucks 39 01-19-2012 11:02 PM
Tags
460, 50, 54, exhaust, f150, ford, header, headers, ll, mainford, manifold, manifolds, oem, truck, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
