Who needs a speedometer anyway
Pulled the Tcase today. I had to pull the entire thing anyway to replace the gasket between the tranny and Tcase, and I'm also going to pull the tranny and replace the clutch.
Anyway, I have removed the yoke and seal, and now... I can't figure out how to get the drive gear off. If it's like the bw1356 linked above, there's a retaining clip behind the gear that will be a PITA to remove and replace.
And yes, the gear is SHOT.
-Matt
-Matt
Well this is odd. I noticed that some of the bolts on the crossmember didn't match, suggesting it had been toyed with before. Then when i got the gear out, it's a 6 tooth.
I found a gear calculator online, and apparently I should have an 8 tooth drive gear with an 18 tooth driven, 3.55 gears, and 235/85/r16 tires. So I'm guessing the transfer case has been swaped out and the PO ignored swapping the speedo gear. That might explain the wear, if the threads are opposite on the gears. Anyway, a new gear is like $65, so I'm going to the junkyard tomorrow.
Rupe, I'm already in Spokane for the summer. All of this carnage is taking place on 14th off of Adams.
#30
Some of them are steel now though, hence the $65 price tag I would think it would be a steel gear as the plastic ones only cost around $20. It was a fiasco trying to get that drive gear for the toploader in my 67 mustang. The parts guy at ford was so tired of me coming in and saying "nope, wrong one" that they splurged and gave me a steel gear. I never knew how much it cost since they didn't charge me for it.
