Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Sign in using an external account
Register Forgot Password?
  #1 (permalink)
Old 04-19-2010, 01:25 PM
93FordCTD 93FordCTD is offline
Garage is empty, add now
93FordCTD is starting off with a positive reputation.
97 van transmission fluid
What should I use? I'm not sure if I have a e4od or a 4r100 (although it looks like a e4od) so what fluid should I use?
Thank You.
  #2 (permalink)
Old 04-19-2010, 02:36 PM
Lazy K Lazy K is offline
Lazy K has a great reputation on FTE.Lazy K has a great reputation on FTE.Lazy K has a great reputation on FTE.Lazy K has a great reputation on FTE.Lazy K has a great reputation on FTE.Lazy K has a great reputation on FTE.
Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles Have a look here if doing a fluid change. Use fluid with Mercron V spec. For example Mobil1 ATF.
  #3 (permalink)
Old 04-19-2010, 05:44 PM
Ok so it is alright to use Mercon V, I read so many horror stories about MV on a e4od I was afraid to use it.
Thank You.
Tags
1996, 97, 97van, checking, diesel, flluid, fluid, ford, fotd, fuid, tran, transmission, transmussion, van, vsn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
