Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 04-19-2010, 05:26 AM
highteckredneck's Avatar
highteckredneck highteckredneck is offline
2002 Ford F-150
highteckredneck is gaining momentum as a positive member of FTE.
johnbradley cinguler
160 extra horsepower from a 4.6L
i was doing some research online and i found this article from hot rod magazine and they did a build up on a ford 4.6L and thought i would share it for the guys that thing these motors have no power
Ford 4.6 Engine - Junkyard Jewel Ford 4.6l 2v - Engine Build Up - Hot Rod Magazine
__________________
2006 F-250 6.0L, 6" lift 35" TOYO open county MT/ 20" XD monster wheels, 4" turbo back MBRP exhaust with 5" tip, Banks 6-gun tuner and IQ monitor, rancho dual steering stabilizers, high idle switch, blue spring update, ARP studs, powermax turbo, EGR deleted, dieselite coolant filter, 6.4L banjo bolts, new HPOP, new standpipes, 08 exhaust gaskets.
  #2 (permalink)
Old 04-19-2010, 06:51 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
1999 Ford F-150
My Garage
BURNSTOUGHFORD is gaining momentum as a positive member of FTE.BURNSTOUGHFORD is gaining momentum as a positive member of FTE.
The new hot rod magazine shows a new set of heads for the 4.6l they flow so much better than even there ported PI heads. I think they said 453 hp from the same engine by switching to the new style heads and cam. I think trick flow made them.
Cant wait to see someone bolt these puppies to a 5.4l truck engine and see what kind of numbers it can pull bellow 5200 rpm.
I know the heads in the new mag are designed to address the severe flow issue with the stock 2v heads.
__________________
2012 F-150 SCREW 3.5TT FX4 3.73
2011 Mustang GT Premium Auto 5.0
2010 Taurus SEL
1999 F-150 SCAB 5.4l Lots of Mods
Tags
2003, 453, 453hp, 46, 46l, f150, ford, heads, horsepower, hot, hotrod, hp, made, pi, power, rod
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
