03 Expedition: Codes P2195, P2197 and P0171 - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 04-18-2010, 10:22 PM
MCGA MCGA is offline
MCGA is starting off with a positive reputation.
Unhappy 03 Expedition: Codes P2195, P2197 and P0171
I have a 03 Expedition, 2x4, 4.6l engine w/ 101K miles. It has had a problem with a rough not quite grinding noise when it gets warm. It sounds like it was coming from underneath the drivers seat. I thought it was most likely the exhaust or catalytic converter area. I thought it was a rattle, but Saturday the check engine light came on and it was idling real rough (almost cutting out) and surging. I immediately thought O2 sensor. That is where my knowledge and experience stops. Took it to Autozone, and the following codes came up: P2195, P2197 and P0171. All of these pointed to the O2 sensors. My questions are as follows:
P2192 says "Lack of O2 sensor - Bank 1, Sensor 1"
P2197 says "Lack of O2 sensor - Bank 2, Sensor 1"
In my lack of time I replaced the front "up stream" sensors on the right and left. I still have the surging and rough idle! Where is Bank 1 and Bank 2? I assumed that since they both said sensor 1 I assumed they were the ones before the catalytic converter. Am I correct with O2 sensor?
I was also assuming that the P0171 was related to the bad O2 sensors. I have read that O2 sensor is often misdiagnosed for P0171.
Any direction will be greatly appreciated!
Thanks!
Mike
Old 04-19-2010, 12:47 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
You have a large vacuum leak, probably the PCV elbow at the top rear of the engine.
Old 04-19-2010, 10:35 PM
Found what I think is PCV...
I think I found the PCV elbow. The elbow was sucked in... I s this it? I pulled the hose off, and there was a small hose on the unit that teh rubber hose was attached to, and I pulled it off. Water or some other fluid cam pouring out of the hose and the plastic piece that the rubber elbow is attached to. Is this the PCV? How do I change the rubber elbow, it appeared to be attached to the non-hose end in a way that it won't come off. There does appear to be a hole in the rubber elbow in the area that is sucked in. Appreciate your help!
Old 04-19-2010, 10:41 PM
Compare what you found to the images on this page to see if you have the right thing.
1998 Ford Expedition Vacuum Assembly
Old 04-20-2010, 07:10 PM
This seems to be a reoccurring problem on this board. If only we would write the same thing so the search would pick up exactly what we needed. Oh well, it would be a boring message board!
Anyway, got it fixed! It was the rubber 90 degree elbow at the very rear of the manifold. Still don't know if it was the elbow for the PCV, MAS or the ABC valve. Anyway, I couldn't make it to the Ford parts shop, so I went by AutoZone and they only had an elbow the same size in a radiator bypass hose. It is on and no air is leaking around it. Is is only to leave this type of hose connected, or should I get the more flexible rubber one from Ford?
Anyway, THANKS to allpro!!!!!! only wish I had found it before I replaced teh 2 up stream O2 sensors. With a 101K miles I guess they needed changing anyway.
Thanks again!
Mike
Old 04-20-2010, 08:28 PM
Quote:
Originally Posted by MCGA View Post
they only had an elbow the same size in a radiator bypass hose. It is on and no air is leaking around it. Is it okay to leave this type of hose connected, or should I get the more flexible rubber one from Ford?
If it works, stop fixing it. LOL
Who's "allpro"?
Old 04-21-2010, 04:58 PM
Sorry!!!
Thanks to alloro!!!!! No truer statement said...."If it works, stops fixing it"!
Old 09-02-2010, 01:05 PM
ncdac875 ncdac875 is offline
ncdac875 is starting off with a positive reputation.
04 Expedition Codes P2195, P2197, I had the same problem with the vaccuum assembly 90 degree hose being worn out and deteriated. I just want to say thank you guys, you saved me a lot of money.
Old 06-10-2012, 04:43 PM
RoundRockMike RoundRockMike is offline
RoundRockMike is starting off with a positive reputation.
Thumbs up
Thank you, thank you, thank you!!! My '03 Expedition has 97K miles on it and just threw these 3 exact same codes. I reached to the back of the intake and found the problem immediately after reading the info on this thread. 30 minutes and $5 later, the problem is fixed.
Old 07-23-2012, 02:40 PM
John XL John XL is offline
John XL is starting off with a positive reputation.
I appreciate this forum indeed. I reach around the back and found huge hole at the elbow. after changing hose, truck not turning off while idling however, its still sputtering during acceleration.
Old 07-23-2012, 11:21 PM
Smile
I also noticed the same thing. Even though the codes didn't come back, it wasn't running great. Going up hills it was sluggish and you could feel the hestitation at full throttle. Took it to the dealership to have the spark plugs and fuel filter changed, since we did have about 97K miles on it. The problem seems to be fixed for good now. No hesitation and better gas mileage.
P2195, P0059, P1000, P0330, U0121, P0351... so many codes!! Please help!!! AGrayson84 1997-2006 Expedition & Navigator 4 11-01-2016 10:35 AM
‪P0171, P0174‬, ‪P2195, P2197‬ codes after cleaning throttle body HelenT Modular V8 (4.6L, 5.4L) 0 10-09-2016 01:35 AM
Rough idling Peripheralxmvmnt Escape & Escape Hybrid 4 07-02-2013 02:49 PM
Engine Code Help P2196, _2197 and P0171 MCGA Modular V8 (4.6L, 5.4L) 5 04-04-2012 02:23 PM
'03 Expedition codes (rough idle) twindaddy66 1997-2006 Expedition & Navigator 1 08-19-2010 12:33 AM
Tags
03, 150, 1998, 2003, 2004, 2195, catalaytic, expedition, explorer, f150, ford, mountaineer, p0171, p2195, p2197
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
