I have read VERY Little on 7.3 but IIRC they Dont use Ford Gold coolant
might want to jump over to the 7.3 forum
VC-9 is an iron cleaner
I'll be using some ELC for the refill.
I was using Evans coolant.
I'm concerned about rust formation because I flushed with tap water when the oil cooler went out before I pulled the water pump, and the water has been in the block for a couple of weeks.
I have also posted in the 7.3 forum
Thanks for the help.
Reason: spelling
