Factory Radio won't trun on. - Ford Truck Enthusiasts Forums
Old 04-18-2010, 04:33 PM
Fordzilla80's Avatar
Fordzilla80 Fordzilla80 is offline
Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.Fordzilla80 has a great reputation on FTE.
I have been looking for a Factory Ford Electronic Radio for my 1980 F100 for quite some time.Well,awhile back I picked one up from an 85 F250.I swapped my factory plug to the 85 style,added the memory wire to the clock memory circuit,and ran the speakers.Well,when I went to turn on the radio,I had nothing.I checked all my connections,and they were all fine.I was getting power on the radio side of the main connector.Well,I figured old radio,so i'll just look for another one.Well,I got a hit on two others,and tested them both.Same exact problem.None of them will turn on.There's no display,no sound,no anything.I decided to take them all apart and test all the solder points and wires to check and see if the radios are getting power internally.All the radios are getting power to just about every point I can try.I really don't understand it.It's as if there's nothing wrong,but they still won't turn on.Is there some kind of capacitor or something that could be blown causing the radio to not come on?All suggestions are greatly appreciated.Thanks guys.
Old 04-18-2010, 07:05 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
Does the clock light up?
You've talked about power, but how about your grounds? Do you have a good chassis ground as well as the pigtail's ground?
Old 04-18-2010, 07:54 PM
My clock has the same exact problem,it does nothing,but gets power everywhere.
The grounds are good,i've checked and cleaned and rechecked everything.
Old 04-21-2010, 08:43 PM
Anybody else got any ideas?
2001 F250 5.4 Crank no-start Faded_Memories 1999 to 2016 Super Duty 3 01-10-2015 05:23 PM
All of the sudden truck won't start 79F250isalive! 1973 - 1979 F-100 & Larger F-Series Trucks 1 10-19-2014 05:58 PM
Installed radio now no turn signal or parking light! 79F250isalive! 1973 - 1979 F-100 & Larger F-Series Trucks 0 10-08-2014 04:25 PM
Radio won't turn on Fordzilla80 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 25 02-23-2010 06:23 PM
91 Ranger dash lights and radio out lawboy Electrical Systems/Wiring 7 02-11-2002 09:08 PM
Tags
1980, 2004, blown, check, f100, f150, factory, ford, oem, power, problem, radio, raido, stock, truck, turn, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
