87 f150 302 engine won't idle. - Ford Truck Enthusiasts Forums
Old 04-17-2010, 04:34 PM
chas87f150 chas87f150 is offline
chas87f150 is starting off with a positive reputation.
my 87 f150 with the 302ci engine won't idle. Runs OK at 800-1000 rpms but the moment I let off on the gas peddle it dies immediately. Have new fuel pumps (in tank pumps and hi pressure). Any ideas?
Old 04-17-2010, 05:45 PM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is gaining momentum as a positive member of FTE.DBGrif91 is gaining momentum as a positive member of FTE.
Did you change the fuel filter when you changed the pumps? Also check the regulator by pulling the vacuum hose off of it. If any gas drips out of it the regulator is bad.
Old 04-18-2010, 07:15 PM
Quote:
Thanks DBGrif91 - I did change the filter but did not check the regulator. I will do that this evening and let you know.
Old 04-18-2010, 08:05 PM
khadma's Avatar
khadma khadma is online now
Carpenter Local 745
khadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud of
Is there pressure at the rails? Pressure at the schrader valve?
Can you hear the pumps priming?
These trucks were prone to electrical issues.
Fuel pump relay
Fuel pump regulator
TPS
Even bad replacement fuel pumps.
Injectors
Check to make sure you have fuel at the rails.
Good low pressure fuel pumps are a must.
If everything is good, check emissions and computer.
Old 04-19-2010, 02:23 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I would suspect its the IAC.
Old 04-20-2010, 09:08 PM
DARREN: Thanks for the help. There is pressure at the schrader valve on the fuel rail - it shoots up about 2-3 inches so it seems adequate. Strangely enough i went to buy a fuel pressure tester and the only one that came with a schrader valve adapter listed all the makes and models of vehicles the tester supported and no F150s were listed??? The parts guy didn't have a clue as to why so I didn't buy it. Any ideas on this? Yes the pumps prime - I can hear them and I replaced them just last fall. Both in tank pumps (I have dual tanks as well as the in-line hi-pressure pump.) As far as the fuel pressure regulator and TPS - my manuals say they can be cleaned up a bit and reinstalled. I have tried this - but no change. When you say emmisions - what specifically are your thinking of?
TEXASGUY: Thanks for the IAC thought. My manual says to run on idle without any assisted gas and unplug the IAC (IAB) and unpluging it at idle. If the engine begins to run rough or stalls then the IAC/IAB is possibly bad. However my problem is that I cannot idle the engine. The moment I let of on th gas peddle the engine dies immediately. So I have a bit of a problem trying this test. Any ideas on this. I hate to just go out an buy new parts and hope they fix the problem. I prefer to test them if possible, but in this case I may have to just buy a new IAC?
Thanks Guys!
Old 04-23-2010, 08:45 AM
DBGrif91's Avatar
The IAC can be cleaned as well. If you have a manual then it should explain the procedure for it.
Won't idle Ford4you 1987 - 1996 F150 & Larger F-Series Trucks 38 03-09-2016 07:01 AM
Help! Truck won't stay running. cnobles10 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 11-04-2015 02:54 PM
turn key and getting nothing koke_kyle Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 12-19-2014 07:41 PM
87 F150 fuel Problems vcobler 1987 - 1996 F150 & Larger F-Series Trucks 2 10-19-2011 03:26 AM
87 302 Can't set timing. Harleymw 1968-2013 Full Size Vans 9 05-14-2004 09:54 PM
Tags
1980, 302, 5o, 87, 91, electrical, engine, f150, ford, fuel, idle, lx, mustang, pump, test, truck, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
