Drum to Disc brake conversion using Explorer disc brakes - Ford Truck Enthusiasts Forums
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Old 04-17-2010, 05:22 PM
FLJ FLJ is offline
FLJ is starting off with a positive reputation.
Question Drum to Disc brake conversion using Explorer disc brakes
I am interest in converting the rear drum brakes to disc brakes on my '82 F150 with a 9" inch rear.
I have heard that it is possible to use the rear disc brake set up from a Ford Explorer.
Has anyone done this or aware of this and what is involved?
Thank You in advance.
<!-- / message -->
Old 04-24-2010, 11:20 PM
sdg0080's Avatar
sdg0080 sdg0080 is offline
sdg0080 is starting off with a positive reputation.
yeah its off an 8.8 explorer rear end. very easy and very cheap too...
sdg0080's Avatar
you need everything off the rear brake of the explorer. from the axle tube out...
Old 09-08-2015, 01:40 AM
khaitan's Avatar
khaitan khaitan is offline
khaitan is starting off with a positive reputation.
1986 F150
Quote:
Hey there, I have 9" too in my truck and considering converting to disc brakes. Is there is a specific year in the explorer that I need to pull the disc brakes out of. And will it be a simple pull out and install or do I need to make any changes to the axle. Thank you in advance.
Cheers!
Old 09-08-2015, 01:42 AM
khaitan's Avatar
Hey, did you end doing the conversion? If yes, can you tell me more about if you ran into any issues or challenges?
Cheers!
Rear Axle Options to Match Crown Vic IFS Swap flowney 1973 - 1979 F-100 & Larger F-Series Trucks 21 10-17-2016 09:59 PM
my Son just purchased a 61 F100 IDIoit 1961 - 1966 F-100 & Larger F-Series Trucks 9 08-15-2016 10:10 AM
rear Drum to disc conversion Multipierce 1997 - 2003 F150 18 06-01-2016 12:30 PM
Rear disc brake conversion 12ozd 1967 - 1972 F-100 & Larger F-Series Trucks 16 11-06-2014 03:13 PM
Salvage Yard Rear Axle Best Guesses lbumpers 1973 - 1979 F-100 & Larger F-Series Trucks 8 11-03-2014 06:26 PM
Tags
1973, 9, brake, bronco, changing, conversion, disc, drum, explorer, f250, ford, mountaineer, ranger, rear, rotor, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
