cab swap
cab swap
ok so i have a 1993 f250 ext cab 4x4 long bed w/ 460, ed4od tranny w/ 238000 miles that im going to possibly fix up (engine and tranny over haul-6"lift-paint tires wheels are the things i would like to do). the bed is beat up pretty bad and the cab has some really bad rust on the cab corners, both doors need a lot of work in side and out ant the interior is in rough shape, now i recently picked up a 1992 f150 ext cab 4x4 long bed w/ 351, e4od tranny w/ 262000 mile for $850, the body is in good shape and the truck runs really well starts right up with no problem, its amazing how clean this truck is the only bad spot on the whole body is a slight rust spot developing on the drivers side cab corner.....imagine that.
so im looking for input on what to do, should i swap the 150 body and put it on the 250 frame or should i just overhaul the 150's engine and tranny........any suggestions.
thank you!!!!!
thank you!!!!!
