cab swap
Old 04-17-2010, 10:23 AM
tredizz52's Avatar
tredizz52
tredizz52 is offline
cab swap
ok so i have a 1993 f250 ext cab 4x4 long bed w/ 460, ed4od tranny w/ 238000 miles that im going to possibly fix up (engine and tranny over haul-6"lift-paint tires wheels are the things i would like to do). the bed is beat up pretty bad and the cab has some really bad rust on the cab corners, both doors need a lot of work in side and out ant the interior is in rough shape, now i recently picked up a 1992 f150 ext cab 4x4 long bed w/ 351, e4od tranny w/ 262000 mile for $850, the body is in good shape and the truck runs really well starts right up with no problem, its amazing how clean this truck is the only bad spot on the whole body is a slight rust spot developing on the drivers side cab corner.....imagine that.
so im looking for input on what to do, should i swap the 150 body and put it on the 250 frame or should i just overhaul the 150's engine and tranny........any suggestions.
thank you!!!!!
gilby959798
02-28-2013 08:02 PM
tredizz52
12-01-2010 12:51 AM
78sd250
04-19-2007 10:56 PM
lud04X
Washington Chapter
04-11-2007 04:39 PM
hell on wheels
16
11-08-2004 11:29 PM
Quick Reply: cab swap
