03 expedition wont start--how do you test fuel relay - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 04-16-2010, 09:53 PM
jsmallwood_2000 jsmallwood_2000 is offline
jsmallwood_2000 is starting off with a positive reputation.
I have a 03 Expy that has been intermittently shutting down, sometimes it restarts right away, sometime it doesn't. The fuel pump is fairly new and it has a new fuel filter. I am being told that it is the fuel pump relay that is part of the PCM, and that it is unserviceable and I must replace the entire module. I believe it is the R303 relay in question, but not sure.
My question is where should I be testing for voltage and amperage to determine if the relay is working or not? I have a good meter (Fluke87) just need to know what to connect to in some detail.
Thanks
Joel
Old 04-17-2010, 07:23 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
The fuel pump relay is integral to the CJB and is not an individually serviceable component. You either have to replaced the complete CJB or you'll have to McGyver it with an external relay should the relay be defective.
You can check its output at the inertia switch (DK GN/YE wire).
Personally, I'd replace the PCM Power Relay as an inexpensive first step. While I rarely advocate "throwing parts" at a problem, I do make exceptions for intermittent problems that are otherwise difficult to trace down.
Old 04-17-2010, 10:35 AM
projectSHO89--
Thanks for your response. My situation has changed a bit. Now it is dead and wont restart, so at least its not intermittent
I took out relay 203 (PCM) and exchanged it with another one already in the panel. I checked them closely before I did this and they appear to be the same #, etc. This did not hep my problem, so if I am understanding you correctly this probably rules out the PCM Power relay. ??
I have checked to be sure the inertia switch is not tripped but have not gone any further yet. Next step is to get to the inertia switch and check for power there. If this isn't the problem I guess I am looking at Relay 303? Any tips on the McGiver approach? I am somewhat technical, have access to lots of "stuff" and have access to an eletrician/electronics guy to help me out if necessary. Thankfully there is Dairy Queen and he has a fondness for Blizzards!!!
Thanks
Joel
Old 04-17-2010, 01:10 PM
Now that it's dead, it will be easier to diagnose.
Does the PATS system prove out at key-on? No use wasting time elsewhere if the security system has disabled the engine.
Does the fuel pump run for 1-3 seconds at key-on? Listed at the fuel filler opening with the cap off. If the fuel pup runs, do you have adequate fuel pressure at the rail? Use a fuel pressure gauge to measure.
Do you have a "No Crank" or a "Crank but does not start" condition?
Make your voltage check as I prescribed. You should see that wire go hot during the initial pump priming time.
Old 04-17-2010, 02:51 PM
OK--that was fun
PATS system is good--flashes every 2 seconds in off--turns on for about 3 seconds when turned to run/start. then goes out while cranking. I think thats how its supposed to be?
I have a crank but no start condiditon. Do not hear the pump running.
Finally dug deep enough to get to the inertia switch. (that was the fun part) It is functioning properly--have continuity, shake it a bit, lose continuity, then reset it and it works.
Do not have voltage at the DK GN/YE wire when the key is cycled. Is this supposed to have voltage anytime the key is on, or just when fuel pressure in the rail is down? I do not have a fuel pressure tester, so I am unable to test that at this time.
Old 04-17-2010, 07:02 PM
UPDATE!!!!!
I finally got it! Ended up pulling the fuse box (central juction box) and decided to disect it. Found relay 303 melted and smoked.
Now just to figure out if I am smart enough to cross rference the relay and solder in a new one or bite the bullet and buy a whole new fuse box.
Old 04-18-2010, 08:28 PM
You can probably splice in a generic relay that piggybacks the bad R303. That's what is sometimes done when the trailer running lamp relay goes out in the SD trucks.
Old 04-19-2010, 08:22 AM
I have been doing some looking for a replacemetn relay that I can put in place---what I dont know is the wiring layout, control voltage, etc to make sue I dont get the wrong one.
Any suggestions for the "right" one??
Thanks
Old 06-25-2010, 11:39 AM
norabyrd norabyrd is offline
norabyrd is starting off with a positive reputation.
I was told my fuel pump relay switch needs to be replaced as I am experiencing the same issues, it will intermittenlty shut off while driving, sometimes start right a way or takes about 10-15 minutes to start back up. Was this easy to fix or replace.
Old 06-25-2010, 11:43 AM
Old 06-27-2010, 10:32 AM
00Harleydavidson 00Harleydavidson is offline
00Harleydavidson is starting off with a positive reputation.
I was told that my fuel-pump control module need to be replaced but then found that the alarm system (smart key) went dead in my 2000 Ford F150 and would not let my fuel pump turn on. After switching to my second key I have never had the problem again.
Old 02-04-2014, 09:15 PM
Joshua W McCarrel Joshua W McCarrel is offline
Joshua W McCarrel is starting off with a positive reputation.
I get low voltage to the inertia switch with key on. I notice that it has 12 volts initially then drops down. Is this normal? I suspect a bad fuel pump but want to verify before I drop the tank.
Old 02-04-2014, 09:46 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
If you turn the ignition key to "ON" and don't crank the engine the fuel pump only recieves power for about two seconds.
Old 02-04-2014, 09:56 PM
Yes that seems to be the case. I am checking it at the output on the CJB. According to a schematic I found the only thing between this and the pump is the inertia switch.
Frankly I was hoping it would be the fusebox as I am not looking forward to dropping the tank.
Old 02-09-2014, 09:25 AM
Update:
Was able to confirm no voltage to the inertia switch. Swapped pump and running again. Thanks for the help.
2000 F250SD Fuel Pump relay location nomad27 Modular V10 (6.8l) 21 03-08-2017 04:51 PM
Brake Drums - 1977 F250 Joel Cassell 1973 - 1979 F-100 & Larger F-Series Trucks 1 06-21-2015 05:50 PM
1977 F-250 Steering Box - Fitting Size Joel Cassell 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-07-2015 02:52 PM
Relay 303 data sheet--specifications jsmallwood_2000 1997-2006 Expedition & Navigator 1 04-19-2010 09:22 PM
351w to 460(seriously) treefort Computer Chips & Tuners 6 07-10-2001 10:48 AM
Tags
03, 351, 87, diagram, expedition, ford, fuel, pump, r303, ranger, relay, start, test, windsor, wiring, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
