Towing mirrors - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Towing mirrors
Old 04-28-2010, 09:27 AM
grec-o-face's Avatar
grec-o-face grec-o-face is offline
grec-o-face has a great reputation on FTE.grec-o-face has a great reputation on FTE.grec-o-face has a great reputation on FTE.grec-o-face has a great reputation on FTE.
Super Duty's from 99-02 (if equipped) are power only - NON-lit, and NON-heated.
Starting in 03 (if equipped) they came pre-wired for power, lights & heat.
If you have a 99-02 you can use the stock pre-wired power wires to run the mirror adjustments. And you can tap into other wires for directional and heat feeds.
There are LOTS of write-ups out there on adapting 03+ mirrors to 99-02 trucks.
I'm just waiting to come across some 08's at the right price.
Old 04-28-2010, 07:57 PM
divedeep1's Avatar
divedeep1 divedeep1 is offline
divedeep1 is starting off with a positive reputation.
check out 2008 Ford Super Duty Towing Mirror Retrofit Kit for 99-2007 F250 F350 F450 Trucks. They have the entire fold and telescope 08 type. $1500 bucks though. I am waiting for something cheaper.
Old 04-28-2010, 09:07 PM
KRAWLER10 KRAWLER10 is offline
KRAWLER10 is starting off with a positive reputation.
Got them installed, bought them off ebay. No wiring, plugged right up. Boy, now i can see those objects lurking around the sides and rear of vehicle. Literally took me 10 minutes per side.
Old 04-28-2010, 11:12 PM
clintusaf's Avatar
clintusaf clintusaf is offline
clintusaf is gaining momentum as a positive member of FTE.
Quote:
got any Pics?
Old 04-29-2010, 11:55 AM
TennesseeMustangPerf's Avatar
TennesseeMustangPerf TennesseeMustangPerf is offline
TennesseeMustangPerf has a good reputation on FTE.TennesseeMustangPerf has a good reputation on FTE.
Quote:
Same here. I am looking into designing a retro fit kit that will allow non-folders/telescopers to be converted. Hopefully I will also be able to develop a kit that converts the pre-08s too. The glories of having a machine shop at my disposal.
Old 08-22-2010, 11:18 PM
Snowdrift3r's Avatar
Snowdrift3r Snowdrift3r is offline
Snowdrift3r is gaining momentum as a positive member of FTE.
On another note, my mirrors are becoming stiff to pull out / push in. Any recommendations on the best way to lube them and what type of lube. I was thinking a light coat of lithium
Old 08-23-2010, 12:11 AM
Pinky Demon's Avatar
Pinky Demon Pinky Demon is offline
Pinky Demon is gaining momentum as a positive member of FTE.Pinky Demon is gaining momentum as a positive member of FTE.
I currently like my concave towing mirrors, I just wish I had the side lights.
Old 10-04-2010, 12:47 AM
9402fordguy's Avatar
9402fordguy 9402fordguy is offline
9402fordguy is starting off with a positive reputation.
Question
Quote:
Originally Posted by stvwrld View Post
Just replaced my 05 driver mirror today. You'll have to take the door panel off and see if it has a 7 pin connector, it's located up high on the door kind of under and infront of the window/lock/mirror controll. I found them all over the net but got this one for $166! NEW! looks and fit great, check it out....look for 08's for you but dosent look like they have them.
2005 Ford F-350 Mirrors - AM Autoparts
Great link!
Do you know who makes those mirrors they sell and more importantly have you been happy with them?
That is the best price by far I have seen for a set of signal mirrors. I hate not having the lights on my '02 and despite everyones enthusiasm for the 2008+ mirrors, I DO NOT like the looks of them... Way too square and blocky for my taste as well as the main mirror actually being smaller in size. I love the look and function of my towing mirrors, but I just need the lights in them.
I've been looking on Ebay for some take-off OEM mirrors but every time I find a set they want your first born for a scratched up used set.
Old 10-04-2010, 03:43 AM
wallz's Avatar
wallz wallz is offline
wallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud ofwallz has much to be proud of
9402....
Have you tried car-part.com
Should have no problem finding one for your price range there.
Old 10-15-2010, 02:52 PM
sscarboro's Avatar
sscarboro sscarboro is offline
sscarboro is starting off with a positive reputation.
Im about to buy an 07 F250 with the small power mirrors, my question, Does Ford normally use the same wire harness for all models and just not employ some of the features? EG power but no signal, would the add on mirror with turn signal feature perhaps plug into the harness and voila, Turn signals on the mirror???
I plan on buying a set from 1aauto.com They make a great product at a very good price and warranty. Used them on my 05 Silverado and they were awsome.
Steve
Old 02-21-2011, 10:19 AM
7-point-3's Avatar
7-point-3 7-point-3 is offline
7-point-3 is starting off with a positive reputation.
I got a pair of manual '08s for my '03 and am VERY happy with them. Any 'adjusting' that's required now helps to increase the ammount of excercise I get
Old 02-21-2011, 01:16 PM
Quote:
Originally Posted by Monster-4 View Post
Do yourself a favor and pony up for the 08+ mirrors. They are way better in my opinion then the 99-07 mirrors.
www.partsguyed.com
Nooo, do not get the 2008+ mirrors, they suck! The 2003's are so much better, you should buy mine when I take them off to do the... um, well, nevermind WHY I am taking mine off.
  #28
Old 02-21-2011, 01:30 PM
89CrewCab 89CrewCab is offline
89CrewCab is starting off with a positive reputation.
Quote:
I also bought a set full manual, non-lighted mirrors from a 2009 F-something50 XL for about $215 shipped from a wrecking yard in MN to SoCal. I saved only $100 by going used vs. new (from Ed & his shipping was more $$) and was concerned about used. Once they arrived, that concern was "out the window" They are "like new". I wanted OEM and didn't want to pay extra cash for power/lights. I couldv'e gotten the new Kool-Vue for about a little over $400, but I was spooked over some of the things I read about vibration. Installation was a breeze and they are a big improvement over the paddle mirrors. I also get a little exercise
  #29
Old 02-21-2011, 02:33 PM
Monster-4's Avatar
Monster-4 Monster-4 is offline
Monster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud of
Quote:
Let me know. I love the '08 mirrors I probably can't afford them but PM me anyway.
  #30
Old 02-21-2011, 03:25 PM
Sounds good, thank you!
2004 Ford F150 Heritage Truck Power Turn Signal Telescoping Towing Upgrade Mirror Pair 1ATony Vendor Specials, Discounts, Product Announcements & Group Buys 0 06-05-2014 12:23 PM
Need A New Mirror bly8397 1999 - 2003 7.3L Power Stroke Diesel 4 03-01-2013 02:34 PM
Signal mirror conversion SpeedRebel09 1999 to 2016 Super Duty 13 02-25-2011 12:52 AM
Need new mirrors HeathJohnson Excursion - King of SUVs 53 03-24-2010 03:09 PM
tow mirror upgrade? indebt 1999 - 2003 7.3L Power Stroke Diesel 6 08-22-2006 12:03 PM
Tags
03, 08, 2000, craigslist, duty, ebay, f250, f350, ford, king, mirrors, ranch, super, tow, towing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
