4R70W NO 2-3 SHIFT
Old 04-16-2010, 04:11 PM
RAYBURGH's Avatar
RAYBURGH
RAYBURGH is offline
4R70W NO 2-3 SHIFT
Hello
I need diagnostic help on my 2000 F150 4.6 4R70w trans. All trans operations work correctly once or twice a day. Then there is no 2-3 up shift. Manual downshift to 2 works all the time and will get me home.
Did an electrical diagnosis and found that the PCM wire that controlls the SS2 (shift solenoid 2) has 12 volts with key in the run position. It should only have voltage for the 2-3 shift.
Checked the SS1 and the voltage was correct for the 1-2 shift. Checked the resistance on the PCM harness wireing that had to do with the transmission and everythink was OK.
Replaced the PCM, with no change on trans operation.
Help.
RAYBURGH
Old 04-16-2010, 05:15 PM
Ron W.'s Avatar
Ron W.
Ron W. is offline
Old 04-17-2010, 08:25 AM
RAYBURGH's Avatar
RAYBURGH
RAYBURGH is offline
Thank you.
Does a bad solenoid account for having 12V present with key on? There must be a feedback in the trans someplace. Remember I replaced the PCM and the nothing changed.
RAYBURGH
Old 04-17-2010, 10:27 AM
Johnny Langton's Avatar
Johnny Langton
Johnny Langton is offline
Originally Posted by RAYBURGH
Thank you.
RAYBURGH
ALL PCM controlled solenoids and relays have 12V positive sent to them at all times,the PCM controls the grounding of those devices for control purposes.
JL
tbon63
06-20-2021 04:14 PM
Brain's 97 Diesel
30
12-19-2015 06:49 PM
kjensen1011
07-23-2015 07:39 PM
300-six
03-11-2014 12:11 PM
phrgcrw
09-23-2013 10:46 AM
Quick Reply: 4R70W NO 2-3 SHIFT
