V10 Service Manual - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
V10 Service Manual
Old 04-16-2010, 04:15 PM
JEV JEV is offline
JEV is starting off with a positive reputation.
V10 Service Manual
Anyone have a link for a service manual for the V10's? I have to change out the oil filter cooler adapter on our 2000 Excursion and it would be nice to have some direction before I tackle that job.
Thanks,
JEV
Old 04-16-2010, 11:50 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
Quote:
Thanks,
JEV
Here's the text, there are drawings but I'm not able to post them, looks like a lot of work though.
<TABLE width="95%"><TBODY><TR><TD>SECTION 303-01B: Engine — 6.8L
</TD><TD align=right>2000 F-Super Duty/Excursion/Motorhome Chassis Workshop Manual
</TD></TR></TBODY></TABLE>
IN-VEHICLE REPAIR
<HR>Oil Filter Adapter —4x4
****** name=tps_proctitle content="Oil Filter Adapter —4x4">Removal
  1. Remove the front drive axle assembly; refer to Section 205-03 .
  1. Remove the LH engine mount; refer to Engine Mounts in this section.
  1. Drain the engine oil and remove the oil bypass filter.
  • [IMG]file:///C:/TSO/tsocache/MEL-PC_5580/SYO~us~en~file=GA2677A.gif~gen~ref.gif[/IMG]
  1. Drain the engine cooling system. For additional information, refer to Section 303-03 .
  1. Disconnect the oil pressure sender electrical connector.
  • [IMG]file:///C:/TSO/tsocache/MEL-PC_5580/SYO~us~en~file=GV0606A.gif~gen~ref.gif[/IMG]
  1. Remove the oil pressure sender.
  • [IMG]file:///C:/TSO/tsocache/MEL-PC_5580/SYO~us~en~file=GA2678A.gif~gen~ref.gif[/IMG]
  1. Slide back the hose clamp and disconnect the lower radiator hose from the oil filter adapter.
  • [IMG]file:///C:/TSO/tsocache/MEL-PC_5580/SYO~us~en~file=GA2679A.gif~gen~ref.gif[/IMG]
  1. Remove the bolts.
  • [IMG]file:///C:/TSO/tsocache/MEL-PC_5580/SYO~us~en~file=GA2684A.gif~gen~ref.gif[/IMG]
  1. Remove the rear nut and the oil filter adapter and discard the gasket.
  • [IMG]file:///C:/TSO/tsocache/MEL-PC_5580/SYO~us~en~file=GA2685A.gif~gen~ref.gif[/IMG]
Installation
  1. NOTE: Clean and inspect the mating surfaces and install new gaskets.
    Position the oil filter adapter and install the rear nut.
  • [IMG]file:///C:/TSO/tsocache/MEL-PC_5580/SYO~us~en~file=GA2693A.gif~gen~ref.gif[/IMG]
  1. Install the four front bolts.
  • [IMG]file:///C:/TSO/tsocache/MEL-PC_5580/SYO~us~en~file=GA2686A.gif~gen~ref.gif[/IMG]
  1. Position the lower radiator hose on the oil filter adapter and install the clamp.
  1. Install the oil pressure sender.
  • [IMG]file:///C:/TSO/tsocache/MEL-PC_5580/SYO~us~en~file=GA2687A.gif~gen~ref.gif[/IMG]
  1. Connect the oil pressure sender electrical connector.
  1. Install the oil bypass filter.
  • [IMG]file:///C:/TSO/tsocache/MEL-PC_5580/SYO~us~en~file=GA2691A.gif~gen~ref.gif[/IMG]
  1. Install the LH engine mount; refer to Engine Mounts in this section.
  1. Install the front drive axle assembly; refer to Section 205-03 .
  1. Fill the engine with Super Premium SAE 5W-30 Motor Oil XO-5W30-QSP or equivalent meeting Ford specification WSS-M2C153-G.
  1. Fill and bleed the cooling system. For additional information, refer to Section 303-03 .
<HR>
Battery Drain JEV Excursion - King of SUVs 1 12-05-2011 03:50 PM
Anyone concerned about Net Neutrality? You should be... four-sixty-power The Next Generation 0 02-02-2011 05:47 AM
Double Cardan dust boot JEV 1999 to 2016 Super Duty 2 11-23-2010 09:45 AM
'04 Rear End Shudder JEV 2004 - 2008 F150 14 12-16-2008 11:33 PM
Brake Caliper Bracket PN??? JEV 1999 - 2003 7.3L Power Stroke Diesel 13 07-03-2008 10:06 AM
Tags
2000, access, excursion, f350, ford, maint, manual, menu, oil, pressure, removal, service, spec, switch, truck, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
