Firestone ride-rite airbag install 08 F250 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-15-2010, 07:27 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Well, got me a set of airbags on the back end of the truck to help with stability.
So here are some pics, pretty straight forward to do.
First two is what the bags look like installed:
This one is the compressor. Since I have the short bed, I mounted it on the piece of steel in front of the tank
Now the tank, mounted under the drivers seat...
Here is the outside of the last pic. Outside air so you can air up tire, bikes
Inside the truck:
Guage is mounted on the hump since I don't have the cup holders there. I mounted it low as I don't need to touch them all the time. Dual controls, so I can adjust each bag on its own
last pic I just threw in there as to show how I got it all in the cab. Used the same pass thru as the shifter.
So easy enough for anyone to do.
Old 04-15-2010, 08:15 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Great pics, thanks for posting!
I want them but can't justify them yet. I don't have anything as heavy as your 5th wheel!
Old 04-15-2010, 08:21 PM
senix's Avatar
Ruschejj gets some credit to...I had asked him how he liked his.
Old 04-15-2010, 09:08 PM
Tom's Avatar
Yeah, I've seen his setup. This is when the jealousy set in! I've wanted them ever since I had my '07 F150. But I don't often spend money when I can't justify it...and I simply don't tow heavy things often enough!
Old 04-15-2010, 10:24 PM
Fordfanatic4life Fordfanatic4life is offline
Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.
i have that exact same setup in my truck...
just recently the electrical connectors on the pressure switch rotted off.. you might wanna coat that area in water proofing to prevent moisture.
even my mounting is in the same places as yours.
overall i REALLY like the system as a whole and have no complaints.
Old 04-16-2010, 05:16 AM
senix's Avatar
I was thinking I would paint all the connections with some black paint.
Old 04-16-2010, 06:45 AM
pbeering's Avatar
pbeering pbeering is offline
pbeering is gaining momentum as a positive member of FTE.pbeering is gaining momentum as a positive member of FTE.
Spray the fittings, connections, and the air bag hardware with Fluid Film. Don't paint them as the solvent in the paint can eat at the tubing.
Old 04-16-2010, 08:31 AM
senix's Avatar
Quote:
thanks for the tip...
Old 04-16-2010, 08:53 AM
Glenn Jenne's Avatar
Glenn Jenne Glenn Jenne is offline
Glenn Jenne is gaining momentum as a positive member of FTE.Glenn Jenne is gaining momentum as a positive member of FTE.
Hello Senix, what is the tongue weight of your fiver? I had the airbags in my F-350 (used Airlift instead of Firestone and they worked great). I got them just to take the little bit of sag out of the truck I noticed when I hitched up my fiver. My tongue weight is right at 2K. I have not hooked up the camper to the 450 I just bought yet, hoping I will not need the airbags for this truck. The back end is a lot "beefier" than the 350 was and I am hoping not a lot (if any) sag will occur when I hitch up.
Old 04-16-2010, 08:57 AM
senix's Avatar
my hitch wt comes in at about 2300 lbs. loaded with water and everything
Old 07-30-2010, 09:10 PM
vairman vairman is offline
vairman is starting off with a positive reputation.
Great Install - Need some help for similar install
Senix, thanks for the pictures of your install. This is just what I am doing. Where did you hook up the power? I do not have upfitter switch and want to make sure I do it right.
Thanks for any advise you can provide.
Old 07-30-2010, 09:21 PM
pbeering's Avatar
Wire directly to the battery. This is not something that will draw unless you push the switch.
Keep wires and air tubing away from sharp edges and hot surfaces. Fluid Film on all fittings and connections.
Old 07-31-2010, 09:46 PM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
Looks good, but IMHO mounting the compressor under the truck is asking for troubles.
I have the set, but never hardwired the compressor. I added cigarette plug to it and tire chuck, while the gauges have the air hose with tire valve on it.
It is not likely you need to adjust the airbags during the drive, so having portable compressor I can use it on my trailer wheels and other vehicles as well.
This is high quality compressor. The popular compressors sold in automotive places last for about one inflation of big tire.
BTW the Firestone gauges are not even. When I push both valves at the same time for the inflation, the needles come about 7 psi apart with equal pressure.
Old 07-31-2010, 10:20 PM
spinella's Avatar
spinella spinella is offline
spinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to behold
i mounted my compressor behind my rear seat. its out of the elements.
Old 07-31-2010, 10:31 PM
senix's Avatar
Will have to look again at which wire, but I found a power source under the dash with ignition on only that I am drawing from.
This allows the compressor to fill the tank as needed without the use of the upfitter switches.
THERMOSTAT REMOVAL with PICS BLADE35 6.0L Power Stroke Diesel 36 01-08-2015 04:50 PM
Bad Habit all dressed up for a night on the town bad_habit_F350 1973 - 1979 F-100 & Larger F-Series Trucks 16 05-09-2014 04:20 AM
Build Thread: 1993 f150 restoration project npd23 1987 - 1996 F150 & Larger F-Series Trucks 17 01-15-2013 08:25 PM
Bored. So I took some pics. hammerhead90 1987 - 1996 F150 & Larger F-Series Trucks 32 08-28-2011 12:40 AM
Pics of my 1977 SuperCab 77 Supercab 1973 - 1979 F-100 & Larger F-Series Trucks 12 08-10-2011 08:46 PM
Tags
07, 08f250, airbags, bc, explorer, f150, f250, firestone, ford, install, installation, installing, ram, ride, rite
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
