2002 Explorer Power Window Problems - HELP - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 04-15-2010, 05:12 PM
Jeff Hildreth Jeff Hildreth is offline
Jeff Hildreth is starting off with a positive reputation.
I have a 2002 Explorer and none of the windows will work. Just stopped suddenly. Checked fuses 17 internal and 6 external and they are OK. Checked blue/black power wire to switch and it has power (all wires have power to them). Bought a new switch and they still don't work! Door locks work and rear hatch opens with switch at hatch. Any suggestions?
Thanks
Jeff
Old 04-16-2010, 11:31 AM
alloro alloro is online now
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
That's nice, but isn't the inside fuse #14 for the power windows? If the fuse is okay then check out the accessory delay relay #601 by swapping it with the one next to it.
Old 04-16-2010, 04:56 PM
Sorry, it was #17, drain bamage while typing yesterday. It was a pain to get to the data relay and I replaced it. No help, still none of the windows work. either at the drivers door or individually. Checked all the wires going to the switch and they are hot. Any more suggestions?
Thanks
Jeff
Old 04-16-2010, 05:50 PM
Well if you have +12v at the switch then you must've lost the ground. All of the windows as far as I know rely on the ground at the drivers master switch to work properly.
Old 04-17-2010, 11:31 AM
I found the ground and jumped it and now they WORK. Thanks a lot and I really appreciate your assistance.
Jeff
Old 04-17-2010, 02:39 PM
Now you can hit the drive-thru again.
Old 07-08-2013, 05:30 PM
Jay Biglove Wilson Jay Biglove Wilson is offline
Jay Biglove Wilson is starting off with a positive reputation.
The tailgate window hitches.
Where can I find the hitches for attach the window of the tailgate.
Old 07-08-2013, 08:33 PM
Quote:
The dealer or a junkyard.
Can't open rear hatch Olafs 7.3 ex Explorer, Sport Trac, Mountaineer & Aviator 4 08-29-2016 10:24 PM
parting out 2003 Mountaineer (fits 2002-2005 Explorer) bronco6767 Ford Truck Parts for Sale 2 06-22-2016 10:16 PM
2004 explorer windows quit working - jabro Explorer, Sport Trac, Mountaineer & Aviator 9 01-19-2016 04:55 AM
New rear wiper motor replaced on 1999 Explorer. Neo01 Explorer, Sport Trac, Mountaineer & Aviator 2 08-01-2014 12:40 AM
Wiring Diagram for rear window defrost circuit 2002-2005 EATC RMBC Freeride Excursion - King of SUVs 5 12-29-2013 11:48 PM
Tags
2002, 2003, 4x4, excursion, explorer, ford, fuse, power, problem, problems, probs, truck, window, windows, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
