Ignition Switch Tumbler Issue
Old 04-16-2010, 08:41 AM
deeznuts822's Avatar
deeznuts822
deeznuts822 is offline
Did you try lifting up on shifter when turning back? Those ign seem to be pretty pricey mine was about ten bucks
Old 04-19-2010, 01:35 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
Originally Posted by Lazy K
https://www.ford-trucks.com/forums/8...ition-fun.html Read here. The post by BChance gives a diagram of the assembly and the proceedure to get at it.
Thanks for the link.
I tried that and moving/wiggling the shifter up and down, there was no difference. Yeah, I know that I can get one for 15-20 bucks, but I would rather get a Motorcaft one.
I'm going to replace the lock cylinder soon. Hopefully, that fixes it.
Old 04-19-2010, 08:08 AM
Brian Abington's Avatar
Brian Abington
Brian Abington is offline
Mine is doing a similar thing. Its really hard to turn forward some times, like the wheel lock is engaged so I have to back up to off and then go forward again to start it. However when I get out it dings like its in ACC position still,so I have to move it a bit with the keys out to get the dinger to stop...
however the other day I thought I would try turning it with out the key in to see how far it would go. I could start the truck with no key in the ignition. I plan to replace mine because if some one breaks in to take my cd player, and decides to try turning the tumbler....they get my truck to.
Old 04-20-2010, 05:00 AM
TexasGuy001
What do you mean dings like in the ACC position. The door chime should only ding when the keys are in the ignition and the door is open.
Mine has started initiating the door chime even when there are no keys in it.
That sucks about the no key start. Mine doesnt do that.
Old 04-21-2010, 04:33 PM
TexasGuy001
My new ignition lock cylinder arrived today. I got a Motorcraft set from NPD for the ignition and doors. I have an issue with the passenger side door lock and I didn't want to have to have 2 keys for the truck anyway. Later tonight, I will probably change it out and see if it fixes the issue. Fingers crossed.
Old 04-22-2010, 03:40 AM
TexasGuy001
I replaced the ignition lock cylinder and everything seems to be normal now. Hopefully, that was the issue.
Old 09-12-2016, 01:28 AM
mxer0022's Avatar
mxer0022
mxer0022 is offline
Originally Posted by TexasGuy001
If I buy a new one, I'm getting a Motorcraft one.
Does anyone know the difference between the 6 different lock cylinder part numbers on Rock Auto? Orielly is the same way.
Search for 'ignition lock cylinder' | O'Reilly Auto Parts
RockAuto Parts Catalog
MOTORCRAFT Part # SW2398 {#F3DZ11582C}
No. 3 Cut Letter C
$48.79 $0.00 $48.79
MOTORCRAFT Part # SW2399 {#F3DZ11582D}
No. 4 Cut Letter D
$48.79 $0.00 $48.79
MOTORCRAFT Part # SW2400 {#F3DZ11582E}
No. 5 Cut Letter E
$50.79 $0.00 $50.79
MOTORCRAFT Part # SW2396 {#F3DZ11582A}
No. 1 Cut Letter A
$50.79 $0.00 $50.79
MOTORCRAFT Part # SW2397 {#F3DZ11582B}
No. 2 Cut Letter B
$50.79 $0.00 $50.79
MOTORCRAFT Part # SW6383 {Includes Tumbler #1L3Z11582A}
From 8/30/95
$58.89 $0.00 $58.89
Did anyone ever figure this out? I'm looking at getting a new tumbler as well but dont know what all the options are.
Old 09-12-2016, 08:44 AM
Scndsin's Avatar
Scndsin
Scndsin is online now
I don't know either, but this is what was in the box when I changed mine. Note the description at the head of key:
Old 09-13-2016, 11:58 AM
mxer0022's Avatar
mxer0022
mxer0022 is offline
So I'm guessing it's just the amount and depth of the tumblers making the key cut more complex?
Old 09-13-2016, 12:08 PM
Scndsin's Avatar
Scndsin
Beats hell outa' me. But it would "seem" so. This thread is the first I've seen where a parts supplier has called out those specifics. The locksmith I use & would ask is 20 miles away & too busy to call, but one these days I would ask if at the counter.
I just know those first 5-6 "stations" correspond to the ignition & the remainder are the doors.
Old 06-10-2019, 05:42 PM
Janis Vogel's Avatar
Janis Vogel
Janis Vogel is offline
its only 20 bucks.
mikeinri
07-25-2023 01:25 PM
Jared Rumple
11-28-2021 09:21 PM
bobinyelm
06-10-2019 09:25 PM
afonda
1999 to 2016 Super Duty
04-10-2018 06:39 PM
superduty2001
07-25-2016 12:15 PM
Quick Reply: Ignition Switch Tumbler Issue
