Oil Bath vs Paper Air Cleaner
Paper filter was standard, but oil bath was an option. Oil bath has that "vintage" look, but does not filter as well, and are a pain to clean. (yes, they do need to be cleaned about every 15,000 miles). I would use the paper filter, as you will get good filtration, easy maintenance (elements are available at most auto parts stores, may take a day or so to come in from warehouse), and the correct look. If you like the look of the oil bath, clean the element real good with kerosene, let it dry out, dip it in oil and let the excess drip out, wipe the inside of the housing clean, fill it with oil to the line, and put it together. Oh, and use SAE 30 oil.
I agree, the paper is a better filter than the oil bath. However, how about converting the oil bath to a paper filter element? I kept the nostalgic look and got the better filtration. Something not mentioned previously is that the metal mesh in the oil bath gets clogged with 50-60 years of gunk. I tried cleaning mine with solvents but couldn't get it clean. When I cut that mesh portion off and installed the paper filter, the engine reved up faster. I believe that the mesh was restricting the flow.
Good luck, Jag
Good luck, Jag
Maybe only drawback is cleaning.
Oil Bath
An oil bath air cleaner consists of a round base bowl containing a pool of oil, and a round insert which is filled with fibre, mesh, foam, or another coarse filter media. When the cleaner is assembled, the media-containing body of the insert sits a short distance above the surface of the oil pool. The rim of the insert overlaps the rim of the base bowl. This arrangement forms a labyrinthine path through which the air must travel in a series of U-turns: up through the gap between the rims of the insert and the base bowl, down through the gap between the outer wall of the insert and the inner wall of the base bowl, and up through the filter media in the body of the insert. This U-turn takes the air at high velocity across the surface of the oil pool. Larger and heavier dust and dirt particles in the air cannot make the turn due to their inertia, so they fall into the oil and settle to the bottom of the base bowl. Lighter and smaller particles are trapped by the filtration media in the insert, which is wetted by oil droplets aspirated there into by normal airflow.
Oil bath air cleaners were very widely used in automotive and small-engine applications until the widespread industry adoption of the paper filter in the early 1960s. Such cleaners are still used in off-road equipment where very high levels of dust are encountered, for oil bath air cleaners can sequester a great deal of dirt relative to their overall size, without loss of filtration efficacy or airflow. However, the liquid oil makes cleaning and servicing such air cleaners messy and inconvenient, they must be relatively large to avoid excessive restriction at high airflow rates, and they tend to increase exhaust emissions of unburned hydrocarbons due to oil aspiration when used on spark-ignition engines.<SUP style="WHITE-SPACE: nowrap" class=Template-Fact title="This claim needs references to reliable sources from November 2007">[citation needed]</SUP>
Should have said that I took that off the internet. I did know that oil filters work well but being a carpenter and shade-tree mechanic I could not have explained the workings so eloquently. Both my trucks have oil bath cleaners and I clean them yearly, certainly more than they need due to miles driven.
Uh huh.
B9TE9600M .. OIL BATH AIR CLEANER / Fits: 1957/60 F100/700 272/292.
An oil bath air cleaner does a far better job of filtering air than any paper air cleaner element...especially when it comes to fine dust.
With an oil bath, you'll never have to buy a replacement paper filter element, which can be difficult to find in autoparts stores for trucks of this vintage.
1957/60 F100/350: As original, there were TWO different air cleaner elements:
1957/60 223 & 1957 272/292: B7A9601C (Motorcraft FA9) / 7.18" I.D. / 9.45" O.D. / 3.47" high / Obsolete
1958/59 272/292 & 1960 292: B8C9601A (Motorcraft FA62) / 6.68" I.D. / 9.19" O.D. / 7.08" high / Obsolete
