No hot air from heater at idle? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-14-2010, 11:29 PM
RaftWW RaftWW is offline
RaftWW is starting off with a positive reputation.
Even after being fully warmed-up, the heater in my 2004 F350 6.0 doesn't put out any heat at idle. Within 5-10 seconds after driving down the road and getting the RPMs up, hot air finally comes out. Then after sitting at a light for a couple minutes, the heater blows cold air.
Any thoughts on the cause and the fix?
Thanks!
Old 04-14-2010, 11:46 PM
jlmotox's Avatar
jlmotox jlmotox is online now
jlmotox is gaining momentum as a positive member of FTE.jlmotox is gaining momentum as a positive member of FTE.
check your coolant level!
Old 04-15-2010, 03:30 AM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Poosible causes that I have seen:
Coolant level (as mentioned)
Slipping belt
Failing water pump
Failing thermostat
Start with checking the coolant level and inspecting the serpentine belt. Those are the easiest to inspect.
Old 04-15-2010, 04:59 AM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
Most likely: failing thermostat.
Did you check temp gauge and is it low when you don't get cold air.
If not, if you have automatic temperature control, the problem is in the valve that regulates coolant flow.
Old 04-15-2010, 09:48 AM
Quote:
Coolant level (as mentioned) Just had it flushed and a new reservoir 2 months back
Slipping belt Doesn't look like it
Failing water pump Gawd, I hope not.
Failing thermostat That's what I was thinking...
Good input from all. Seems like I'll be fore-warned now when I take it to the mechanic.
Thanks!
Old 04-15-2010, 01:43 PM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
I'll put my money on the water pump. It is a common issue on the earlier 6.0 PSD.
Well, low coolant is very common too, but a quick glance eliminates that.
Old 12-21-2010, 12:20 PM
TFCO TFCO is offline
TFCO is starting off with a positive reputation.
Hey Guys does anyone know the outcome of this issue. (How was it repaired)
Old 12-21-2010, 03:46 PM
And the answer is...
Blown Head Gasket, Oil Cooler clogged with sand (left over from casting the block?) and low water levels!
New oil cooler, machined heads, upgraded head bolts (160 ft-lbs) and some other little things.
Grand Total: $5,300
Please don't say I got bent over the chair.
Old 12-21-2010, 03:47 PM
... and one small benefit
Fuel consumption improved up 2.5 mpg, a little consolation!
Old 12-21-2010, 04:16 PM
bunklash's Avatar
bunklash bunklash is offline
bunklash is gaining momentum as a positive member of FTE.
Glad to hear a positive outcome. Better mileage means a lot these days. We're paying $3.18 a gallon here, bet it's even worse on your end of the world.
Old 12-21-2010, 07:18 PM
LaredoF350's Avatar
LaredoF350 LaredoF350 is offline
LaredoF350 has a good reputation on FTE.LaredoF350 has a good reputation on FTE.LaredoF350 has a good reputation on FTE.
As I was scrolling through the thread I was going to post head gaskets - my 03 had all of the above stuff like yours done...
... on warranty though!
05 6.0 heater blowing cold air cooter05 6.0L Power Stroke Diesel 14 02-27-2014 12:13 AM
Heater suddenly quit working on 2000 V-10 Ex EXv10 Excursion - King of SUVs 15 04-21-2013 06:48 PM
98 Expedition heater kerstingm Expedition & Navigator 21 02-23-2011 08:49 PM
ok, so is my heater core bad? reedytlr93 1997 - 2003 F150 15 01-08-2011 03:11 AM
97 Ranger - turning on heater drops temp gauge to "C" R202INT Ranger & B-Series 1 03-03-2010 08:49 PM
Tags
05, 2004, 60, air, belt, blows, cold, duty, f350, ford, heater, hot, idle, slipping, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
