x springs/plow prep??
i thought i had x springs on my 02 f250 v10 which i believe are rated 6000lbs?
but then i saw this on the ford website...what gives?? how can i tell if i have x springs? my gawr says 5200 lbs front, but my spring code is "XA"and my truck sits higher for sure.
"• Snowplow Package, includes:
—Highest Front GAWR’s (5200 lb. for F-250-350; 6000 lb. for F-450-550)"
This is taken from another thread on the forum.
a 2004 F SuperDuty:
Rear Springs — F-Series
B — 3C34-5560-L
C — 3C34-5A975-D
D — 3C34-5A975-G
E — 3C34-5A975-K
J — 3C34-5A975-J
M — 3C34-5A975-E
N — 3C34-5A975-F
P — 3C34-5A975-C
S — 3C34-5A975-C
2003 manual
Front Springs — F-Series
B — F81A-5310-EA
C — F81A-5310-EA
D — F81A-5310-EA
E — F81A-5310-EA
F — F81A-5310-FA
G — F81A-5310-GA
H — F81A-5310-HA
I — F81A-5310-RA
J — F81A-5310-JA
K — F81A-5310-KA
R — 2C34-5310-AAB, 3,600 lb.
S — 2C34-5310-AAB, 4,000 lb.
T — 2C34-5310-ABB, 4,400 lb.
U — 2C34-5310-ACB, 4,800 lb.
V — 2C34-5310-ADB, 5,200 lb.
W — 2C34-5310-AEA, 5,600 lb.
X — 2C34-5310-AFA, 6,000 lb.
Y — 2C34-5310-VA
Z — 2C34-5310-WA
B — F81A-5310-EA
C — F81A-5310-EA D — F81A-5310-EA
E — F81A-5310-EA
F — F81A-5310-FA
G — F81A-5310-GA
H — F81A-5310-HA
I — F81A-5310-RA
J — F81A-5310-JA
K — F81A-5310-KA
Y — 2C34-5310-VA
Z — 2C34-5310-WA
Front Springs — Excursion
B — YC35-5310-ABC
C — YC35-5310-ACC
D — YC35-5310-ADA
G — YC35-5310-GA
H — YC35-5310-HA
S — YC35-5310-SA
B — 1C34-5560-CB also 3C3Z-5560-CB
C — 1C35-5560-DB
D — YC35-5560-EA
M — YC35-5A975-AA
N — YC35-5A975-BA
S- 3C3Z-5560-CA one you should get for EX spring swaps.
Rear Springs — Excursion
V code fronts..2C3Z-5310-HA get for Ex spring swap.
A — YC35-5560-A
Rear SD 30mm bar.. F81Z-5A772-AA
2007 F-Super Duty 250-550 Workshop Manual
SECTION 100-01: Identification Codes
DESCRIPTION AND OPERATION
Vehicle Certification (VC) Label
Springs
Springs codes are listed (on the VC label) as a 2-part code. The first character listed is for the front springs. The second code listed is for the rear springs. Auxiliary rear springs may also be listed.
Front Springs
AA — 5C34-5310-AMD, 7,000 lb
BB — 5C34-5310-ALD, 6,500 lb
CC — F81A-5310-AHD, 6,000 lb
DD — F81A-5310-AGD, 5,600 lb
EE — F81A-5310-EA, coil
FF — F81A-5310-FA, coil
GG — F81A-5310-GA, coil
HH — F81A-5310-HA, coil
II — F81A-5310-RA, coil
JJ — F81A-5310-SA, coil
KK — F81A-5310-TA, coil
TT — F81A-5310-AFD, 5,200 lb
VV — F81A-5310-AED, 4,800 lb
YY — F81A-5310-UA, coil
ZZ — 2C34-5310-WA, coil
Rear Springs
BB — 5A975, leaf
CC — 5A975, leaf
DD — 5A975, leaf
FF — 5560, leaf
HH — 5A975, leaf
JJ — 5A975, leaf KK — 5A975, leaf
NN — 5A975, leaf
It may be useful. You will have to figure it out.
a 2004 F SuperDuty:
B — 3C34-5560-L
C — 3C34-5A975-D
D — 3C34-5A975-G
E — 3C34-5A975-K
J — 3C34-5A975-J
M — 3C34-5A975-E
N — 3C34-5A975-F
P — 3C34-5A975-C
S — 3C34-5A975-C
2003 manual
B — F81A-5310-EA
C — F81A-5310-EA
D — F81A-5310-EA
E — F81A-5310-EA
F — F81A-5310-FA
G — F81A-5310-GA
H — F81A-5310-HA
I — F81A-5310-RA
J — F81A-5310-JA
K — F81A-5310-KA
Y — 2C34-5310-VA
Z — 2C34-5310-WA
B — F81A-5310-EA
E — F81A-5310-EA
F — F81A-5310-FA
G — F81A-5310-GA
H — F81A-5310-HA
I — F81A-5310-RA
J — F81A-5310-JA
K — F81A-5310-KA
Y — 2C34-5310-VA
Z — 2C34-5310-WA
B — YC35-5310-ABC
C — YC35-5310-ACC
D — YC35-5310-ADA
G — YC35-5310-GA
H — YC35-5310-HA
S — YC35-5310-SA
C — 1C35-5560-DB
D — YC35-5560-EA
M — YC35-5A975-AA
N — YC35-5A975-BA
A — YC35-5560-A
Springs
Front Springs
Rear Springs
BB — 5A975, leaf
CC — 5A975, leaf
DD — 5A975, leaf
FF — 5560, leaf
HH — 5A975, leaf
NN — 5A975, leaf
backtrack2015
Fifth Wheel & Gooseneck RV Towing
30
10-13-2017 02:39 PM
18mm, 2001, 2c345310aea, 3c3z5560ca, 3c3z5560cb, buy, diesel, duty, f350, f81z5a772aa, gawr, plow, prep, replace, snow, springs, super
