Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 04-14-2010, 12:31 PM
avesterg avesterg is offline
Garage is empty, add now
avesterg is starting off with a positive reputation.
Max Load for factory installed roof rack?
I searched thru the owner manual, but couldn't find any reference to the maximum load allowable on the factory installed roof rack on my 2007 Expedition. I want to buy a 21 cu ft roof-top carrier, and want to make sure that the factory rack system can handle the weight/load.
Anybody know? Thanks!
  #2 (permalink)
Old 04-14-2010, 03:59 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
I would guess 300-400 pounds total. I think the rood would start to buckle/dent before the plastic snapped though.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 04-14-2010, 04:06 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
pretty sure it says right on the rails 150 lbs. wife has the Expy right now so I can't check for you.
suggest you take a quick look
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #4 (permalink)
Old 04-14-2010, 05:00 PM
gddyup's Avatar
gddyup gddyup is offline
gddyup is gaining momentum as a positive member of FTE.gddyup is gaining momentum as a positive member of FTE.
I just ran outside and looked at mine. I can't find a sticker or label that gives me any info whatsoever for the factory roof rack....
I would guesstimate that each rail will be rated around 100 pounds. I have instaled roof racks on a number of Toyota/Lexus SUVs before and each rail was rated in that area.
I did a google search for the Ford rack but didn't find anything worthwhile....
  #5 (permalink)
Old 04-14-2010, 05:50 PM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
Quote:
LUGGAGE RACK
Your vehicle is equipped with a roof
rack for transporting items on the
exterior of the vehicle. The
maximum recommended load to be
carried on the roof rack is 200 lbs
(90 kg), evenly distributed.
The
cross-bars can be adjusted by using
the thumbwheels at each end. Use
the tie-down loops on the
thumbwheels to secure load.
To adjust the position of the
cross-bar (if equipped):
1. Loosen the thumbwheel at both
ends of the cross-bar (both
cross-bars are adjustable).
2. Slide the cross-bar to the desired
location.
3. Firmly retighten the thumbwheels
at each end of the cross-bar.
Be sure to check that the thumbwheels are tight each time load is added
or removed from the roof rack, and periodically while traveling.
Always ensure that the load is secure before traveling.
Ford Motor Company recommends loading the roof rack only when
equipped with (optional) crossbars, to avoid unintended damage to the
roof panel.
Page 143 of my PDF version of the '07 manual. In the Driver Controls section.
-- Chuck
  #6 (permalink)
Old 04-14-2010, 05:54 PM
berry1234's Avatar
So a body will fit nicely.
__________________
  #7 (permalink)
Old 04-14-2010, 07:04 PM
gddyup's Avatar
Thanks Chuck! Seems as if most racks are probably going to be rated in that same rough area. I guess roof thickness and weight limits are pretty much close across the board for most manufacturers.
Good info to know because I plan on picking up a canoe for the family weekend outings this year. Maybe I can carry it on the roof or maybe not.
  #8 (permalink)
Old 04-15-2010, 06:02 AM
I find having the PDF version of the owners manual very helpful in finding stuff although I had to constantly click Next when searching for "rack" as it stopped every time it found "track." Seems half the manual is devoted to the "entertainment systems."
Implied in Ford's note is that the weight should be on the cross bars, or at least much of it. That's how I read it. We've never used the rack.
Canoe? Just gotta hear your experience that THAT on the roof!
-- Chuck
  #9 (permalink)
Old 04-15-2010, 12:53 PM
thanks all - I had looked at the pdf of the manual but couldn't find it - was looking in the wrong spot! again, many thanks
  #10 (permalink)
Old 04-15-2010, 08:54 PM
gr8dain's Avatar
gr8dain gr8dain is offline
gr8dain is starting off with a positive reputation.
I have a 20 cu ft old X-Cargo carrier that I have used many times on my 2007. Filled it with luggage and Christmas presents. I have never had a problem.
Dain
Tags
2004, expedition, explorer, factory, ford, limits, maximum, post, powered, rack, roof, rook, specs, truck, vbulletin, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
