7.3 liter international, and 7.3 powerstroke - Ford Truck Enthusiasts Forums
General Diesel Discussion SPONSORED BY:
Old 04-14-2010, 10:59 AM
blueeyedfordguy's Avatar
blueeyedfordguy blueeyedfordguy is offline
blueeyedfordguy is starting off with a positive reputation.
hey, found a 7.3 int. from an ambulance, as well as a 7.3 from a wrecker. They are both similar and take 16quarts of oil. What is the difference between these and a 7.3 liter power stroke? Just wondering. Same bell housings??
Old 04-14-2010, 01:26 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
The IDI and Power Stroke are two different engines, nothing is the same except the bellhousing pattern. The IDI is purely mechanical while the Power Stroke needs a computer to run.
Don`t know what the Stroke takes but the IDI takes 10qts. of oil. The 16qts you quote is, I would think, for the E4OD trans that both used.
Old 04-14-2010, 02:10 PM
origcharger origcharger is offline
origcharger has a good reputation on FTE.origcharger has a good reputation on FTE.
Its the International T444E that is basically the same as a 7.3 Powerstroke.
Old 04-14-2010, 03:57 PM
The 16 quarts of oil is hard for me to believe as well but, the engine was rebuilt by a company called pmp or something like that. Sticker on engine sa " this engine requires 16 quarts of engine oil" Hard for me to believe my self. It looks more mechanical than a power stroke, but It is from a wrecker and all. A much larger truck really! Flat bed tilt/ bed wrecker with semi tires. What international 7.3 would this be if it takes 16quarts of oil? I will take a photo of the valve cover sticker if I can.
Old 04-14-2010, 04:08 PM
clem1226's Avatar
clem1226 clem1226 is online now
clem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to behold
my 2000 PS 7.3 holds 16 qts, The spec is only 15qt's but I usually just dump 4 gallons in and call it good for 5000 miles.
Almost 300K and not an issue yet.
Old 04-14-2010, 05:30 PM
Quote:
All 7 of our International T444Es take 19.5 quarts of oil.
First there was the 6.9 IDI International starting about 1984, it evolved into the 7.3 IDI around 1987 and was used till the T444E came out around 1994-95. International, to my knowledge never used a turbo on the 7.3 IDI in mediom duty applications.
Old 04-15-2010, 04:51 PM
Yeah, thats what truck that is. A t444E int. Nice flatbed wrecker. What is that classified as ?? A two ton truck? Can't believe that uses a similar motor to the 7.3 liter powerstoke! Pretty cool! Nice trucks really.
Old 04-15-2010, 05:04 PM
Skip1970's Avatar
Skip1970 Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
so a IDI and a powerstroke 7.3 share the same bellhousing pattern?
Old 04-19-2010, 11:32 PM
bdrummonds's Avatar
bdrummonds bdrummonds is offline
bdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud of
Quote:
95-2003 7.3L powerstrokes ARE T444E's T444E stands for- turbo, 444 cubic inches, electronically controlled. They are the same block, but will have minor differences in turbo configuration, and yes both do hold 16qts of oil
The T444E/ 7.3 Powerstroke is one of the last true medium duty engines, as classified by the DOT. The 5.9L cummins is the other. The duramax, and the VT365 International (6.0L) are classified as light duty diesels. Why? Because of insurance and emissions.
Old 04-20-2010, 01:56 AM
Skip1970's Avatar
Im talking 84 - 94 IDI 6.9 and 7.3 international engines fords had, do they share the same bellhousing pattern at the 95 and up 7.3 powerstrokes?
Old 04-20-2010, 07:46 AM
bdrummonds's Avatar
if the E4OD was used in 84 to 94 then it would be the same, as I do not remember the housings changing.
Old 04-20-2010, 09:38 AM
1960fordf350's Avatar
1960fordf350 1960fordf350 is offline
1960fordf350 is starting off with a positive reputation.
Is the ambulance a ford van front end? Then the difference will be in the the way the motor is plumbed. Those van fronts are tight, and a lot of components were reconfigured to fit in that small bay.
Old 04-20-2010, 12:39 PM
Quote:
well, we are having to change some things from block to block. We will get her going again
Old 04-20-2010, 12:45 PM
Wow, i never knew that. I knew the 7.3 and 5.9 were in the same class
Old 04-20-2010, 10:34 PM
bill11012's Avatar
bill11012 bill11012 is offline
Modular motor junkie
bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.bill11012 has a great reputation on FTE.
Yes. When ford went from the IDI to the PSD they used the same 5 speed on both.
New member from north ga mountains 7.3Litre Moxie New Member Introductions 1 12-16-2015 01:23 PM
2000 F-250 SUPER DUTY 7.3 LITER DIESEL sprinklers 1999 to 2016 Super Duty 0 03-21-2015 09:31 PM
7.3 L swapped into an 2008 F 550? meanjoelake 1999 - 2003 7.3L Power Stroke Diesel 17 12-19-2011 03:09 PM
1997 7.3 versus 2001 7.3 Biscayne 1994.5 - 1997 7.3L Power Stroke Diesel 14 11-11-2011 01:50 PM
Turbo Whistle Louder bigdog194 1999 - 2003 7.3L Power Stroke Diesel 4 12-14-2010 11:21 PM
Tags
59, 73, bellhousing, cummings, desiel, differences, egr, hold, idi, international, oil, powerstroke, quarts, t444, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
