General Diesel Discussion
7.3 liter international, and 7.3 powerstroke
Old 04-14-2010, 09:59 AM
blueeyedfordguy's Avatar
blueeyedfordguy
blueeyedfordguy is offline
hey, found a 7.3 int. from an ambulance, as well as a 7.3 from a wrecker. They are both similar and take 16quarts of oil. What is the difference between these and a 7.3 liter power stroke? Just wondering. Same bell housings??
Old 04-14-2010, 12:26 PM
Lazy K's Avatar
Lazy K
Lazy K is offline
The IDI and Power Stroke are two different engines, nothing is the same except the bellhousing pattern. The IDI is purely mechanical while the Power Stroke needs a computer to run.
Don`t know what the Stroke takes but the IDI takes 10qts. of oil. The 16qts you quote is, I would think, for the E4OD trans that both used.
Old 04-14-2010, 01:10 PM
origcharger's Avatar
origcharger
origcharger is offline
Its the International T444E that is basically the same as a 7.3 Powerstroke.
Old 04-14-2010, 02:57 PM
blueeyedfordguy
The 16 quarts of oil is hard for me to believe as well but, the engine was rebuilt by a company called pmp or something like that. Sticker on engine sa " this engine requires 16 quarts of engine oil" Hard for me to believe my self. It looks more mechanical than a power stroke, but It is from a wrecker and all. A much larger truck really! Flat bed tilt/ bed wrecker with semi tires. What international 7.3 would this be if it takes 16quarts of oil? I will take a photo of the valve cover sticker if I can.
Old 04-14-2010, 03:08 PM
clem1226's Avatar
clem1226
clem1226 is offline
my 2000 PS 7.3 holds 16 qts, The spec is only 15qt's but I usually just dump 4 gallons in and call it good for 5000 miles.
Almost 300K and not an issue yet.
Old 04-14-2010, 04:30 PM
origcharger
All 7 of our International T444Es take 19.5 quarts of oil.
First there was the 6.9 IDI International starting about 1984, it evolved into the 7.3 IDI around 1987 and was used till the T444E came out around 1994-95. International, to my knowledge never used a turbo on the 7.3 IDI in mediom duty applications.
Old 04-15-2010, 03:51 PM
blueeyedfordguy
Yeah, thats what truck that is. A t444E int. Nice flatbed wrecker. What is that classified as ?? A two ton truck? Can't believe that uses a similar motor to the 7.3 liter powerstoke! Pretty cool! Nice trucks really.
Old 04-15-2010, 04:04 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
so a IDI and a powerstroke 7.3 share the same bellhousing pattern?
Old 04-19-2010, 10:32 PM
bdrummonds's Avatar
bdrummonds
bdrummonds is offline
95-2003 7.3L powerstrokes ARE T444E's T444E stands for- turbo, 444 cubic inches, electronically controlled. They are the same block, but will have minor differences in turbo configuration, and yes both do hold 16qts of oil
The T444E/ 7.3 Powerstroke is one of the last true medium duty engines, as classified by the DOT. The 5.9L cummins is the other. The duramax, and the VT365 International (6.0L) are classified as light duty diesels. Why? Because of insurance and emissions.
Old 04-20-2010, 12:56 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Im talking 84 - 94 IDI 6.9 and 7.3 international engines fords had, do they share the same bellhousing pattern at the 95 and up 7.3 powerstrokes?
Old 04-20-2010, 06:46 AM
bdrummonds's Avatar
bdrummonds
if the E4OD was used in 84 to 94 then it would be the same, as I do not remember the housings changing.
Old 04-20-2010, 08:38 AM
1960fordf350's Avatar
1960fordf350
1960fordf350 is offline
Is the ambulance a ford van front end? Then the difference will be in the the way the motor is plumbed. Those van fronts are tight, and a lot of components were reconfigured to fit in that small bay.
Old 04-20-2010, 11:39 AM
blueeyedfordguy
well, we are having to change some things from block to block. We will get her going again
Old 04-20-2010, 11:45 AM
blueeyedfordguy
Wow, i never knew that. I knew the 7.3 and 5.9 were in the same class
Old 04-20-2010, 09:34 PM
bill11012's Avatar
bill11012
bill11012 is offline
Modular motor junkie
Yes. When ford went from the IDI to the PSD they used the same 5 speed on both.
Quick Reply: 7.3 liter international, and 7.3 powerstroke
