85' 460 EGR removal questions - Ford Truck Enthusiasts Forums
Old 04-13-2010, 10:12 PM
jd72hiboy jd72hiboy is offline
jd72hiboy is starting off with a positive reputation.
I just bought a complete running carburated 460 out of a 1985 f-250 from fan to bellhousing and looking to install in my 72 F-250 4x4 to replace the tired 390. I want to remove the air pumps and EGR equip. (no emissions testing where I live) I have a edelbrock 750cfm carb and looking a purchasing a Weiand or Edelbrock non EGR intake as well as L&L ultra flow headers. What complications or problems might I run into? whats the best way to block off where the crossover tube goes into the back of both heads? Can I install a mechanincal fuel pump without problems?
thanks
Old 04-19-2010, 06:59 PM
phatjack81's Avatar
phatjack81 phatjack81 is offline
phatjack81 is starting off with a positive reputation.
If I remember right, you can take the tubes out and plug them with expansion plugs, I think that's what they're called, (they look like small frost plugs). The mechanical fuel pump is doable how easy it is depends on what did away with when they switched to an electric fuel pump. If it has a block off plate bolted on where the pump goes then that's an easy one, if it doesn't then you'll probably need an old timing chain housing that has the opening for the fuel pump and the threaded bolt holes. You'll also need the eccentric cam that bolts to the top timing chain gear and maybe a longer bolt. It might be easier to just put an electric inline fuel pump in, like a Carter or a Holley on the frame close to the tank.
Old 08-13-2010, 11:49 PM
ambulanceguy ambulanceguy is offline
ambulanceguy is starting off with a positive reputation.
How did you make out with the engine running with no emission controls? I have a 1985 460 that someone took most of the emissions off of and it will not drive when cold. After it idles and heats up a while it's ok. It will also overheat on the interstate but is ok driving through town. Just wondering if you had any similar issues or if anyone has any ideas.
Old 08-17-2010, 01:31 PM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold
ambulanceguy, sounds like whoever removed the emission stuff didn't know what he was doing. If the vacuum advance is not set up correctly, or the choke isn't right, any of a number of issues will cause poor cold running and overheating.
Old 08-19-2010, 07:24 AM
The carb has electric choke so I think it's ok. Any recomendations on the vacumn advance? How/what should be done to it? Mine runs fine in town but overheats as soon as I get on the interstate. Timing off?
Old 08-19-2010, 08:48 AM
Electric choke is probably the stock carb for that engine. Vacuum advance should have vacuum at idle on that system if I remember correctly, I'm pretty sure i have to pull the line off to set timing. If it doesn't have vaccum at idle, run the engine speed up a bit (you can open the throttle a bit and raise the end of the fast idle cam to hold it) and see if you have vacuum then. If not, then you will need to see if the vacuum diagram on the radiator support is still legible. If you can't read it, let me know, I have a new one for mine and can scan it. Once you have vacuum, when disconnecting the line, the engine should slow down, reconnect and it should speed up. If it does not, then try applying vacuum directly to the advance unit, it should hold vacuum, if it doesn't, replace it. If it does, remove the distributor cap and see if the pickup assembly moves when vacuum is applied. Timing should be 8 degrees before TDC at 800 rpm with no vacuum. Be sure you are on the correct end of the scale, most of them run both directions from TDC. Hopefully, you don't have a radiator problem.
Edelbrock 4bbl Intake for 69-72 351W - Fit an 1984 351W? 64deville 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 08-16-2011 10:19 AM
sick 460 when towing USN-Ret. Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 7 08-07-2010 08:20 PM
edelbrock carb problems sandkwagers 1987 - 1996 F150 & Larger F-Series Trucks 6 06-19-2010 08:56 PM
Questions Removing the emissions equipment - 85 460 F250 BVA 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 45 09-16-2009 08:46 PM
Miscelaneous problems (very long) ferrwrench 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-18-2003 04:26 PM
Tags
1978, 460, air, block, carb, delete, econoline, egr, emmisions, ford, plate, removal, remove, truck, tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
