77 f250 on 2.5 rockwells
Wait a second. What am I missing here?
Rotate the driver side output down. The input and rear output are lined up, basically the same shaft straight through.
So why cant you re-index the front to meet your application? The front shaft will be lower than the rear if you re-index that far, and you simply bolt up some shafts.
Ive installed Rocks in this era truck without re-indexing the (married) case at all.
Thats even easier. The driveshaft angles are even better. Though the rear one is a little short, you can move the entire case forward, or drop the case down a little.
Again, this is a piece of cake.
You can run these on their side if you want to. They lube rather well. Once in a while you may find some starvation for the front output bearing, but this is easy to fix with a drill by making a new hole in the case, and rotating the bearing retainer. Only 4 bolts, but this is an extreme case.
Most off road vehicles will splash enough oil and will be off camber enough to lube everything up.
Your not taking 500 plus mile trips right?
abosely
12-10-2015 01:26 PM
byerks
04-27-2015 03:21 PM
2tone250
06-08-2012 11:37 AM
