EXPEDITION 03 WINDOW REGULATOR cable - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 04-13-2010, 06:38 PM
jes7 jes7 is offline
jes7 is starting off with a positive reputation.
hi
i have a 2003 expedition. The REGULATOR cable for the window is torn.
Questions:
Do i need to replace the hole component? Or is it posible to just replace the cabl, wire?.were can i get one?
And how ? any triks/pics?
thanks!
jes7
Old 04-13-2010, 08:26 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
No you can't replace just the cable, you have to replace the entire regulator.
Old 04-14-2010, 01:59 AM
ok. thanks
Old 04-14-2010, 08:57 AM
bumparker bumparker is offline
bumparker is starting off with a positive reputation.
Jes7,
I had to replace the drivers regulator on my 2003 EB. Part was about $90 delivered and reused the original motor. Search the forum, there is a very detailed port with pictures on how to change the regulator. Took me about 1.5 hours becuase I was going slow and taking my time but I could do it in 30 minutes now.
Old 04-15-2010, 05:03 AM
Quote:
Originally Posted by bumparker View Post
Jes7,
Thanks .
Old 04-15-2010, 12:16 PM
there is a very detailed post with pictures on how to change the regulator.
This one?
http://www.ford-trucks.com/forums/72...regulator.html
Old 04-16-2010, 03:57 AM
where can i get a regulator on nett?
Old 04-16-2010, 10:20 AM
Old 04-16-2010, 12:04 PM
Be careful not to get the regulator for pre-09/12/03 vehicles. It's the older non-cable type that won't fit. Here's the one you need:
2003 FORD EXPEDITION Window Regulator
transmission id tag jes775 Clutch, Transmission, Differential, Axle & Transfer Case 2 09-23-2016 01:45 PM
Fluctuating Oil Pressure Lneidlinger 1967 - 1972 F-100 & Larger F-Series Trucks 9 09-29-2015 06:59 PM
2001 F350 7.3 stalled and stranded jes01srw350 1999 - 2003 7.3L Power Stroke Diesel 42 10-12-2013 08:44 AM
2003 Expedition window regulator thacker7 Expedition & Navigator 4 01-22-2013 07:12 PM
Window Regulator: Where to buy? mswpj 2004 - 2008 F150 19 07-06-2012 02:30 PM
Tags
03, 2003, 2004, actuator, cable, cables, change, expedition, explorer, ford, motor, navigator, power, regulator, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
