Need a rear end diagram. - Ford Truck Enthusiasts Forums
Old 04-13-2010, 11:31 AM
klatt_89 klatt_89 is offline
klatt_89 is starting off with a positive reputation.
I have a 2002 F-150 FX4 5.4L SuperCab. The passenger side seal on the rear axle is leaking. It's a 3.55L 9.75 in rear end. Anything else i should replace once i get into it that far on one side? A diagram of how it all fits together would be greatly appreciated!
Thanks
Old 04-13-2010, 02:43 PM
kaboom10's Avatar
kaboom10 kaboom10 is offline
kaboom10 is starting off with a positive reputation.
Old 04-13-2010, 10:37 PM
Thank you!
Old 04-14-2010, 06:14 AM
kaboom10's Avatar
Did it come thru/? I was in a hurry. I have an AllData account for my truck. If there's anything else let me know.
Old 04-14-2010, 06:21 AM
kaboom10's Avatar
Old 04-14-2010, 10:31 PM
Yeah, it came through on the original post, I just had to go through photobucket to see it, I don't think there is anything else, I was curious where the front vent tube runs on the 4x4's tho. Thanks for the help and I'll let you know if I need anything else, thanks again!
Old 04-15-2010, 05:26 AM
kaboom10's Avatar
The vent tube line runs up from the hard brake lines junction IIRC. It's where I replaced my rubber brake line with stainless steel.
Frame Diagram w/dimensions 60 f100 Fshmn62 1957 - 1960 F100 & Larger F-Series Trucks 2 07-08-2014 12:12 AM
Ford 5.4L vacuum line diagram blacknight79 1997 - 2003 F150 0 06-09-2011 01:56 PM
Diagram 01 SuperCrew Steering Linkage gossetm3 1997 - 2003 F150 0 02-07-2011 06:29 PM
92 F250 XLT Fuse Diagram kuzco 1987 - 1996 F150 & Larger F-Series Trucks 1 11-08-2009 06:57 AM
rear axle oil seal purecty 1987 - 1996 F150 & Larger F-Series Trucks 11 08-07-2008 04:17 PM
Tags
150, 1997, 2001, 975, axle, breakdown, diagram, end, ends, f150, ford, fx4, rear, schematics, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
